Old 04-08-2016, 04:32 PM   #1
mikeypx82
My Ride: 2005 BMW 330i
Bi-Xenon headlight circuit diagram needed for retrofit
Can someone post the headlight circuit diagram? I switched out my halogen headlights for Bi-xenon headlights on my '05 330i. I already installed the front and rear level sensors and I made my own wiring harness to connect the headlights to the LCM. This is the only information I could find on how to wire the headlights:
PIN 39 Q22 LEFT headlight actuator/motor
PIN 40 Q11 LEFT headlight actuator/motor
PIN 41 Q12 LEFT headlight actuator/motor
PIN 42 Q21 LEFT headlight actuator/motor
PIN 51 Q22 RIGHT headlight actuator/motor
PIN 52 Q11 RIGHT headlight actuator/motor
PIN 53 Q12 RIGHT headlight actuator/motor
PIN 54 Q21 RIGHT headlight actuator/motor
The connectors that I have are labeled 1, 2, 3, and 4. I'm not sure what order to connect the wires into the LCM. Any help would be appreciated!
mikeypx82 is offline   Reply With Quote
adaptive, headlight, retrofit, xenon
