325ci strange crank/no start - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-09-2016, 03:17 PM   #61
Mr325ci
My Ride: 04 325ci
I have 50 psI at the rail and after about 30 minutes it sinks to 40 psi so residual pressure seems good as well
Mr325ci is offline   Reply With Quote
Old 04-09-2016, 03:21 PM   #62
jfoj
My Ride: 330CiC, M5, X5, E93
Originally Posted by hatetolovee46 View Post
If it was key issue jfoj wouldn't a immobilizer light come on or just not crank at all? Just curious here I like learning new things.
+1 to checking power to injects, and +1 to "proper fuel pressure"(check the damn psi and know exactly...)
We have seen some strange problems with the EWS. Usually there is no light. We have seen crank, no start problems due to flaky keys, this in theory should not happen, but it can and has happened.
Also flaky ignition switches have also caused some unusual problems.
The injectors should have power on one side KOEO (Key On, Engine Off). Some test lights can even flicker a bit on one side of the injectors when the engine is cranking. The DME should be controlling the ground side of the injectors to open them.
Old 04-09-2016, 03:40 PM   #63
hatetolovee46
My Ride: 02 325xi
fuel pump draw = 5 amps
MS 42.0 and MS 43.0 = 3.5 bar (50.76 +/- 2.9 psi)
residual pressure = >3.0 bar (>43.51 psi)
MS S54 = 5.0 bar (72.5 +/- 2.9 psi)
residual pressure = >4.5 bar (>65.2 psi)
fuel pump delivery volume all models
1.12 liter (1.16 quart) in 30 seconds
Check that plugs are indeed fuel soaked after crank attemps, check a plug for spark with spark plug tester (10 bucks usually connects to plug with plug removed and has ground wire you attach to block and you can see spark in clear chamber, at least the ones i've used. Used caution if engine is flooded with gas or spill overs from fuel rail checks.
hatetolovee46 is offline   Reply With Quote
Old 04-09-2016, 03:40 PM   #64
hatetolovee46
My Ride: 02 325xi
Old 04-09-2016, 03:59 PM   #65
jfoj
OP stated in kind of a convoluted way that the engine started and ran on starting fluid.
This means the engine should have spark from the statement he made.
Old 04-09-2016, 08:01 PM   #66
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I skimmmed...saw many recommending fuel pump...consider the fuel filter too. It will get so clogged it'll stop a car...and you could still have fuel pressure when you check it...even through a clogged filter, but enough fuel might not be getting through. If you've never changed it (or either) it's a good time to anyway.
I replaced my fuel pump at something around 200K miles...it was still good...but they fail pretty regularly here.
Did you check fuses in the e-box fuse pack?
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 04-12-2016, 09:09 AM   #67
csscza
My Ride: 2003 325i m class
Ive read that the ews system sends two signals one to ignition one to fuel injectors. so if anti theft system isnt working it might not be sending a signal to fuel injectors. Im experiencing same problem so thats my next check is signal at fuel injector or out put at ews or dme.... good luck.
csscza is offline   Reply With Quote
Old 04-12-2016, 09:18 AM   #68
Mr325ci
My Ride: 04 325ci
I'll be back outside tomorrow playing with it. I hope it's not EWS or something stupid because I just got a new key for the car from the stealer ship last month
Old 04-19-2016, 08:11 PM   #69
csscza
how much did that key cost you?? They quoted us 225 bucks crazy right! Took our 325 to a mech and he found a leak in the oil seperater tube and exhuast side cam sensor was bad and it started right up but still have to get a new key. We are also have to find a new instrument cluster to get it back on the road.
Old 04-21-2016, 12:49 PM   #70
Gracie Dog
My Ride: 2003 325i
Mr325ci, any updates on fixing your No start? I have the same issues.
Gracie Dog is offline   Reply With Quote
crank, e46, fuel, pressure, start
