///M3 Forum
Old 05-19-2016, 10:58 PM   #1
AntonioM3
My Ride: BMW M3 e46
M3 e46 clunk in the rear
Okay, so lately I started to hear a clunk type of sound coming from underneath the car whenever I let off the gas while already accelerated at random speeds. At first it was quieter but not you can not only hear it louder but also feel it. The sound is often 2 clunks right after another and also does it when shifting gears(SMG btw).
I'm no car expert but I do know some stuff, therefore with my knowledge about cars I am worried about couple things! First would be a bad flex disc, second would be bad differential bushings or mounts??????
AntonioM3 is offline   Reply With Quote
Old 05-19-2016, 11:08 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
M3 rears clunk. Then again - M3 subframe mounts crack.
Alan is offline   Reply With Quote
Old 05-20-2016, 02:00 AM   #3
Topazzar
My Ride: '02 M3
The gear shift clunk is normal. Take it out of sport mode and set the gearbox to 3 or 4 and see if you get it then.
Only use sport mode when driving a bit harder than normal and changing gears over 4,000rpm... M3's love that
Topazzar is online now   Reply With Quote
Old 05-20-2016, 09:10 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Next time you have the car up on the lift just have the rear suspension checked out (differential and subframe bushings, shock mounts, etc) and also the driveshaft, guibo/flex disc and the center support bearing
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-20-2016, 08:58 PM   #5
jtmiller
I have been living with this clunk! Brand new diff bushings, subframe bushings, rtabs, welded subframe reinforcement. Still have it! Yours seems like its a little different than mine. But good luck, i know how annoying it is. Have new suspension going in soon, we'll see if its better or not.
jtmiller is offline   Reply With Quote
Old 05-21-2016, 09:25 AM   #6
tedavis01
Mine did yes same thing, ended up being shocks
tedavis01 is offline   Reply With Quote
Old 05-24-2016, 05:04 PM   #7
Sushiholic
My Ride: 06 M3 11 335d 96 Z3
the shock mounts go bad as well....that is a serious clonk
Sushiholic is offline   Reply With Quote
Old 05-24-2016, 08:36 PM   #8
choxor
My Ride: JDM
Check the suspension and bushings, but these cars simply clunk. There's a lot of lash in the LSD. More on one side than the other. It's the way it was designed.
clunk noise, differential, differential bushings, flex disc, knock
