Old 12-08-2015, 02:57 PM   #1
Fudge Monkey
My Ride: 330xi
Sometimes No Fuel Pressure, Not Pump
Lately my 2003 330xi has been having an issue where sometimes it starts, sometimes it doesn't. I have checked and when it does not start, there is no fuel pressure at the fuel rail. It is not the pump/filter because that was replaced the other day at a dealer. It just happened to work afterwards. I doubt it is a fuse issue because it is not completely dead and I will be checking the relay when I get home today. It seems to not start when it is cold out (<32 F), but that could just be coincidence.
Please help.
Fudge Monkey is offline   Reply With Quote
Old 12-08-2015, 03:00 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Swap the horn and fuel pump relay and see what happens.
Fuel pump relay should typically by changed or swapped with the horn relay when the pump is replaced.
Old 12-08-2015, 03:04 PM   #3
Fudge Monkey
My Ride: 330xi
Ok thanks, so far that is my only thought because it is not completely dead like most people encounter.
Max More
Old 12-08-2015, 03:13 PM   #4
Fudge Monkey
My Ride: 330xi
I don't know if it is related, but lately my central locking with the key fob has not always worked as it should. Some times I have unlock the doors/trunk with the actual key.
Max More
Old 12-08-2015, 05:48 PM   #5
jfoj
www.bmwgm5.com
Old 12-09-2015, 08:55 AM   #6
markusmarkus
My Ride: 2001 330Ci
How old is the battery? Google "BMW E46 hidden obc functions" and use test #9 to check you voltages. Definitely swap out the relay as jfoj recommended.
Old 12-09-2015, 10:12 AM   #7
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Pull your back seat up and verify they actually replaced the pump with a new one.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 07-20-2016, 06:25 PM   #8
Dante12
My Ride: 318i Steptronic
Hi, have the same issues on a 320ci, pump, filter, relay swaps, cps sensor, spark plugs, no CEL or codes on INPA and jump start all done, still no start. Before car would start and immediately die. How did you end up fixing this? Or can anyone help?
DANTE12
2002 BMW E46 318i - Orient Blue - Beige Leather - M3 Sports Steering with Paddle Shifts - Android 4.04 Infortainment system - 1200W Alpine D Sub 12" - M3 Front bar - 19" Custom Painted Breyton Magic ET38 8.5J - Projector Headlights & Angel Eyes - LED DRLs in Foglight Ports
2000 BMW E46 318i - Silver - Written off
2000 BMW E46 318i - Bergundy - Sold
Dante12 is offline   Reply With Quote
Old 07-20-2016, 06:36 PM   #9
jfoj
Try a different key and also check to see if there is power to the pump while cranking the engine. NOTE, that there will be around 11.2-11.4 Volts at the fuel pump while cranking, this is normal.
Old 07-20-2016, 10:08 PM   #10
Dante12
Thanks for the response, only have one key unfortunately. However my other e46 with two keys, the faulty key will not crank, and the engine in the case of the non starting car is just about to turn over, string crank.
Pump is running when I switch ignition on (for about 8 seconds) and again when engine is cranking. I had replaced the pump thinking this was the issue, when I connect the older pump out of the tank, I can confirm the pump is getting power.
I have checked the EBox fuses as well for continuity and even visually inspected them, still no go. In checking around for the issue, I noticed the Fuel Pressure vacuum line was disconnected from the knuckle close to the MAF which I reconnected, but still no go. I have not got a fuel pressure tester but when i use a pin to press the Schrader valve after cranking, fuel flows out. Not squirts out or jets out, but flows out....
Would this be pointing towards low fuel pressure? When I first changed the filter thinking the filter was clogged, car ran after a couple of hard cranks and failed starts. Left it idling for about 15 min, then rolled off the driveway for a test drive. There was absolutely no power, until it eventually died 50m up the road. Would not restart and hasnt started since then.
Sorry for the long post
DANTE12
electrical, fuel, fuel pump, fuel pump relay, no start issue
