Old 08-28-2015, 02:34 PM   #1
SlappyCheeks
My Ride: 330i
Royal Purple to Mobil1
Heu guys, I'm about to do my oil change on my 330i. The previous owner had serviced it with RP, I have Mobil1.
Is there any need to do a engine flush before switching to Mobil1? Is there anything I should look out for before doing this?
I used the search function before I made this topic. Could not find a answer.
SlappyCheeks is offline   Reply With Quote
Old 08-28-2015, 02:47 PM   #2
Manny330
My Ride: 02 330i
Send a message via AIM to Manny330
No, if the car has high mileage I would recommend switching to BMW 5w-30 as well.
Stock
Manny330 is offline   Reply With Quote
Old 08-28-2015, 02:50 PM   #3
mikeetastic
My Ride: lots of 3
youre fine at M1.. search the thread here, guys is using the walmart castrol 5w-30 and his car is at 300K+ miles.
mikeetastic is offline   Reply With Quote
Old 08-28-2015, 06:38 PM   #4
Knight
My Ride: '05 330Ci | '01 325i
An oil like Mobil 1 0W-40 has excellent cleaning properties, so it would be a good choice.
The engine flush isn't necessary and some of them are very aggressive to the point of doing more harm than good.
Sticking with a quality oil and filter, along with a proper change interval, is sufficient.
If down the road you pull the valve cover and see a bunch of buildup, then look into some other options.
Knight is offline   Reply With Quote
Old 08-28-2015, 08:01 PM   #5
SlappyCheeks
My Ride: 330i
Thanks for the info, I appreciate it guys!
Old 08-29-2015, 10:18 AM   #6
mikeetastic
My Ride: lots of 3
i stand corrected.. he is using M1 5-30 and his car is at 530K miles
http://e46fanatics.com/forum/showpos...3&postcount=19
Old 08-29-2015, 01:11 PM   #7
Jools
My Ride: 2005 330Ci
If you feel like you need to "flush" your engine (you probably don't, but it's not like it's going to do any harm), a good option is to just up your oil change interval for a bit. Do a few 3000 mile or shorter changes with Mobil 1 0w40 and you'll probably get the exact same effect as running a cleaner through your crankcase.
Jools is offline   Reply With Quote
Old 10-08-2016, 11:04 AM   #8
beameup
My Ride: 2001 330ci
correct oil
2001 330ci e46 104,000 miles--what is the correct oil?????
beameup is offline   Reply With Quote
Old 10-08-2016, 11:11 AM   #9
hitbyastick
My Ride: 2002 325i
Um, no.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 10-08-2016, 01:37 PM   #10
markusmarkus
My Ride: 2001 330Ci
Any oil with "BMW LL01" on the label.
Old 10-08-2016, 06:22 PM   #11
Mr Podman
My Ride: E46 Coupe
Use what Mango is selling:
Mr Podman is offline   Reply With Quote
Old 10-08-2016, 06:46 PM   #12
NorthernCAE46
My Ride: 01 330Ci Convertible
55 gal drum.... this has got to be a joke
NorthernCAE46 is offline   Reply With Quote
Old 10-08-2016, 09:14 PM   #13
lingon300k
My Ride: 2005 325xi Automatic
Oil related problems in a modern car with modern oils are extremely rare. It's likely that you could run your car to 500k miles, easily, without any engine problems, with a completely out of spec oil. Conventional 15w40 for 5k mile OCIs, or 0w20 synthetic for 8k mile OCIs. It probably wouldn't matter as long as you changed it before it went bad.
Having said that, M1 5w30 is a pretty garbage oil for the price. Take a look online, read the specs it carries and the various UOAs. Its only positive attribute is its pour point, and even that, I think, has gone up.
Just look for something with ACEA A3/B3 and/or A3/B4. Or go with Castrol Edge 0w40, which is LL-01 approved--meaning its what you're supposed to be using in this car, the weight doesn't matter--and is available everywhere for ~$25 for a 5 quart jug. It's also a true synthetic and made in Germany. Most Mobil 1 oils are not "true" synthetics.
There's never any reason to do anything when switching oils. A lot of people use a different oil every time they change it.
If you just want to do a flush, use an idle only flush like Liqui Moly Professional. You pour it in before draining the old oil, let the car idle for 10-20 minutes, then drain it out.
lingon300k is offline   Reply With Quote
Old 10-09-2016, 03:51 AM   #14
Mr Podman
My Ride: E46 Coupe
No joke. It is for sale at the Mango Store. And check that price closely - $40.22 per gallon.
Golden oil.
podman
Old 10-09-2016, 09:21 AM   #15
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
engine, mobil 1 0w-40, oil, royal purple
