Old 10-22-2016, 06:34 AM   #1
Fen3ix94
My Ride: 325ci e46
Fuel problems urge
G'day I'm new here but I have a problem with my 2001 e46 325ci manual
I recently have been having hard starts in my e46 so I change my fuel pump and it didn't want to start. Just cranked and then flooded cylinder 6. I changed injector 6 as it was leaking (I cranked the car without spark plugs in to get the fuel out).
I also change my spark plugs and oiled up the cylinders before putting them in.Got the car to idle but discovered fuel being pumped into the intake hose from the throttle body and the hose that comes into the pipe between the air filter and throttle body.
I can get the car to start and idle but it's just pumping fuel into the intake pipe and then stalls out.
It's my only mode of transport so any help would be greatly appricated.
Thank you
Fen3ix94 is offline   Reply With Quote
Old 10-22-2016, 06:50 AM   #2
jfoj
My Ride: 330CiC, M5, X5
The fuel pressure regulator is bad.
http://forum.e46fanatics.com/showthread.php?t=1115137
Old 10-22-2016, 07:14 AM   #3
Fen3ix94
My Ride: 325ci e46
I've got fuel coming out of the f piece but I've also got fuel coming out of the throttle body on cranking
Old 10-22-2016, 10:22 AM   #4
jfoj
Replace the Fuel Pressure Regulator, the diaphragm has a hole in it. The FPR may be part of the fuel filter. Fuel is leaking from the throttle body because it ran down the intake boots.
Replace the FPR.
Old 10-22-2016, 10:27 PM   #5
Fen3ix94
My Ride: 325ci e46
That did the trick! Thank you!
Old 10-22-2016, 11:30 PM   #6
Swiff
My Ride: 2002 330xi
jfoj. How long have you been dealing with BMW's? You are like the Bimmer whisper.
Swiff is offline   Reply With Quote
fuel, fuel filter, fuel pump problems, stalling
