Old 12-25-2016, 07:56 PM   #1
Daustin
My Ride: 1999 bmw 328i
Should i replace the CCV?
The other day as i was backing my 99 328i out of the garage i looked in my rear view and saw an abnormal amount of exhaust. At first i thought it was just very cold so the exhaust was very visible but i got out of the car had checked it for myself, the smoke coming out of my tail pipe was bone white, and was coming out more than normal exhaust. It looked like i had taped a rock-concert fog machine to the bottom of my bumper. I checked a couple different forums and people are saying things about the head gasket, and the ccv, and the anti-freeze/coolant. Here's a short video i took of the problem:
I left it running, thinking maybe there was something in the exhaust that needed to air out and after a couple minutes it DID appear to become less and less. However, the next day i started my car and the same large amount of white smoke came out of my tailpipe. Hopefully, someone can tell me what exactly is wrong with my car? i'm no e46 expert! SEND HELP!
Daustin is offline   Reply With Quote
Old 12-25-2016, 08:27 PM   #2
OnTheFence
My Ride: 2001 330i (and 530i)
https://www.google.com/search?q=e46+...+smoke+exhaust
OnTheFence is offline   Reply With Quote
Old 12-26-2016, 03:16 AM   #3
randy72877
My Ride: 01 330 sport 5m sil/
Looks like normal condensation in cold weather. What was the temperature when you noticed that? Does it burn oil or overheat? If not you are probably just seeing normal condensation. It was -15 in Chicago last week and that weather probably went your way a few days later. (NY plate) Warm moist exhaust will look like steam especially on a cold start in below zero temperature.
Sent from my SAMSUNG-SM-G870A using Tapatalk
randy72877 is offline   Reply With Quote
ccv, exhaust, headgasket, problem, white smoke
