Old 12-08-2012, 11:48 PM   #1
Quadrant5
My Ride: 2000 323i
MDK issue leads to DME suspicion
Hey guys, I could use your help on this one.
I have a 2000 323i 4 door with manual transmission. A couple of months ago I pulled away from a stop light when the EML and DSC lights came on. The MDK (throttle body) also was put into Emergency Operation 2, which allowed me to limp home at 20 MPH.
I ran the codes to see what was wrong. I donít remember exactly which ones came up, but it pointed to the throttle position sensor, which is located inside the MDK. I replaced the MDK with a used one, which didnít work. I replaced that one with a new one, which didnít work. I replaced that one with another new one, which didnít work. It is of interest that when I use my new MDK, the car is in Emergency Operation 1, and occasionally slips into Emergency Operation 2. When I use my original MDK, it stays in Emergency Operation 1. At least I can get to work at 50 MPH.
I have checked, rechecked and rechecked the wiring and found no issues. That led me to believe that maybe there was a problem with the computer. However, I seem to remember that somewhere I read that you werenít supposed to replace the computer under any circumstances (that is, when trying to fix the MDK). That led me to the stealership.
BMW wanted $1,700 to replace the computer. That led me to try to research how to do it myself. I purchased a used computer online and read on the forums how to replace it. I know the EWS system is a challenge when doing this. So I thought I would try flashing my computer using WinKFP using daten 7526765. I had hoped that maybe the programing was corrupted somehow and that flashing it would help. It didnít.
I know that if I want to use the computer I purchased I will have to buy more stuff to deal with the EWS system, which I would rather not do. This is where I could use your help.
Does anyone have experience with a similar problem?
Does anyone have any suggestions on what I might try before getting into reprograming the used computer?
I do have INPA, WinKFP, SSS Progman, NFS, Tool32, NCS Expert and DIS V52 to work with.
Help me Obi-Wan Kenobi, youíre my only hope.
Quadrant5
Quadrant5 is offline   Reply With Quote
Old 12-09-2012, 07:35 AM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Not so fast my friend... I too drive a 00 E46 323i and when I had the same exact codes in my bimmer it turned out that my throttle body was sealed shut by carbon build-up. It was so bad I had to use a hammer and chisel to initially open the flap. So before you go out and purchase a new ECU or re-flash your DME take a little time and clean your throttle and idle control valve while you're in there... Just my two and a half cents worth!
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 12-11-2012, 11:30 PM   #3
Quadrant5
My Ride: 2000 323i
Yeah, I tried that. No dice.
Quadrant5
Old 12-12-2012, 12:05 AM   #4
dslboomer
My Ride: 2001 BMW 330I
Did you follow the reset instruction at the bottom of the link after installing the new MDK? DIS will be the one to use.
http://tis.spaghetticoder.org/s/view.pl?1/06/04/50
dslboomer is offline   Reply With Quote
Old 12-20-2012, 11:58 PM   #5
Quadrant5
My Ride: 2000 323i
Sorry, your link is not valid.
Quadrant5
Old 12-21-2012, 09:35 AM   #6
dslboomer
Where were you for last 10 days?
Sadly the spaghetticoder.org took down E46 service manual since yesterday.
That's real bummer!
Old 12-21-2012, 09:40 AM   #7
Gus330vrum
My Ride: 330ci
That's real bummer!
:/ oh no!
Gus330vrum is offline   Reply With Quote
Old 12-21-2012, 11:13 AM   #8
Quadrant5
My Ride: 2000 323i
That's real bummer!
Unfortunately I have been out of town and very busy. I do believe that you were encouraging me to reset my adaptations using DIS. If that is so, I assure you that I did do that.
Quadrant5
Old 12-21-2012, 12:02 PM   #9
dslboomer
I think that was it. I didn't read through it though.
If you did that with a new MDK, and you still have problem, I think you should start fresh. What codes do you have?
Old 02-01-2013, 07:43 PM   #10
Quadrant5
My Ride: 2000 323i
Sorry, I've been busy, again. I do appreciate your efforts to help. It was a long time ago that I looked at the exact codes. One was, I believe, 169. That just indicates a MDK problem as I recall. The other, I think, was 114. That has to do with a bad signal being sent to the DME from the MDK. Or was it that the redundant potintiometers did not agree with each other? Either way, it seems that the issue is that the MDK is sending the wrong signal (bad MDK), or the signal is not reaching the DME (wiring or connection issue), or that the DME itself is not interpreting the signal right (DME problem).
I don't think it is the MDK, as I have replaced it twice with brand new units and still have my problem.
I don't think it is the wiring because I have checked and double checked and tripple checked it with no problems. Plus there is no evidence of bad connections.
That leaves the DME itself. That also agrees with what the dealership told me when I took it in to them.
Any suggestions?
Quadrant5
Quadrant5
Old 08-29-2015, 12:34 AM   #11
jvidamins
My Ride: 2000 328i Manual
Quadrant5, did you ever resolve this issue? I read your 2 threads thoroughly, as I have a very similar problem/codes. It seems you were still driving the car a year or so after your last post to this thread, so I'm hoping you could enlighten me and anyone who has similar problems in the future what you finally did to fix it. Thanks!
jvidamins is offline   Reply With Quote
Old 08-29-2015, 01:07 PM   #12
Quadrant5
My Ride: 2000 323i
Thank you for asking. I do believe I have finally solved it, and just this week too! I have been meaning to post this but have not had the time. Thanks to your question, I can now hopefully help the community that has helped me so much.
So, first of all, where was the problem? It was not in the throttle body as the codes would have you believe. It was not in the DME, which I did learn how to program / replace in the process anyway. It was, strictly speaking, not a wiring issue. I had continuity accross the loom. However, the fact that many replace the entire wiring harness gives a clue. But I found that to be a very expensive proposition. It seems that the issue is with the individual female connectors that are part of the 52 pin connector at the DME. To access them you take out one of the two sides of the 52 pin connector. Then along the side you will see that each connector has a tab that if pushed, you can pull out the connector by gently pulling on the individual wire. If you cut off the connector (easier than un-crimping it) you can strip the wire and crimp on a new one.
The actual problem seems to be the spring loaded ends of the female connectors. Over time they seem to get pushed back more and more until your connectivity is intermitent. Then this problem arises and codes are thrown.
Now, where would you get these female connectors to replace the worn out ones? I ordered ten different female connectors from BMW or South Atlanta. Upon receiving them I found a number of different ones that looked identical with what I was trying to replace. I decided to use part number 61131393724 because it was the cheapest. My last order of them cost me $0.52 a piece. It cost more to ship them than buy them. Still, it cost much less than a new wiring harness!
These connectors use a special tool to crimp them on. The tool I used is the right kind, but made for a bigger connector. I made it work. I don't have information about a better tool for the job. I thought about soldering the connections. However, a friend of mine who is a millwright and all around knowledgable guy suggested it is better to just crimp. I won't go into detail, but since the original harness is only crimped, I went with his suggestion.
On my car, I replaced one of the connectors some months ago and the problem went away. Recently though, the problem came back with a vengance. So I ended up replacing all ten of the connectors associated with the throttle body. These include pin numbers 4, 7, 9, 10, 14, 16, 19, 20, 43 and 44. The first eight are on one half of the 52-pin connector, 43 and 44 are one the other half.
It has been a week since I did this. So far, I have had no problems whatsoever. I can't say for 100% certain that I have solved the problem. But the logic and evidence seem to indicate that this cheaper approach is effective.
I hope this information is helpful to the forum. I thank all of you who have helped me through this problem. And I thank jvidamins for encouraging me to do this write up.
Happy motoring!
Quadrant5
Old 01-20-2016, 07:45 AM   #13
ernstludwg
My Ride: 2000 323 wagon
Thank you for your detailed info. I too, through deductive reasoning, have pointed myself towards DME. First, MDK keeps throwing the usual TPS codes. Cleaned MDK, fixed for 3 days, or so I thought, while cleaning I naturally went WOT several times (key on?). When it came back I started to order MDK but decided to clear codes and adaptive memory and viola, fixed. Drove 8 miles no problem, give car back to son. He calls from side of motorway doubting my skills. Walked him through clearing adaptive memory and boom he was on his way to work. So I started to order a DME and came across your thread. Makes more sense since it is intermittent and ambient temp seems to effect it. Tonight the connector gets inspected. Could you post pic of the pliers you are using. I think I have some but want to be sure I am on same page.
ernstludwg is offline   Reply With Quote
Old 01-01-2017, 03:40 PM   #14
onemilan
My Ride: 99 Z3
Thanks a lot.
I have the same problem.I wass about to have DME repaired.I will try Your suggestion tomorow.I have replaced MDK and Had the codes coming back.Replaced wiring harness and same thing.When i clear codes and clear adaptations,press throttle four times.Read codes and no codes present.I don`t have to start engine,just let it be turned on and sometimes 10 minutes and EML light comes on.If I clear codes and do it over and start engine it will run fine and some minutes later EML light comes on.I don`t get any other codes but 100 and 169.It has been about two months I fight wit this.First time I had this problem car had 48000 miles,now it has 103000.First time I had dealer fix it and cost 2000.I have read another thread wher guy replaced only wiring from DME to MDK,just those 10 wires and that fix it.I have done the same and it didn`t fix my problem.I will try tomorow check those connectors.I will post update.
onemilan is offline   Reply With Quote
computer, dme, ews, mdk, throttle body
