Old 01-11-2017, 02:35 AM   #1
AbdullaJaafari
My Ride: E46 330ci
I hit a dead end, I can't get in my car in any way
Hi guys,
So, I finally made the purchase and got myself a 330ci imported from Japan.
I drove the car on the first couple of days and was planning to do some thorough cleaning and maintenance in the next few days.
I parked the car for 24 hours, and went back to it last night, the remote key won't open the lock, I tried using the key itself and the lock just spins right and left doing nothing.
I did some googling, for the remote key, some people said it could be the GM5 module, and as for the key, I found that it's a common problem where I need to change the lock's internals.
The problem is, I can't open any door in the car and not even the trunk as the previous idiot owner in Japan has installed a rear view camera IN THE TRUNK'S KEYHOLE! Pissed me off.
I can't access the car in any way.
My assumptions:
-Dead battery
-Dead remote battery
-GM5 issue
-Door lock internals broke
I need a solution on how to get in the car and I'd really hate it if I need to break a window.
EDIT: Broke the window, continuing on this thread here: I had to break my car's window so I access it
AbdullaJaafari is offline   Reply With Quote
Old 01-11-2017, 02:48 AM   #2
Megalocnus
My Ride: 05 330i ZHP/MT
If the battery is the issue, there may be an easier way to power the car by accessing the engine bay:
1. Find a way to unlatch the hood. This can be done by removing the two torx fasteners holding the latch. Break the kidney grille if you have to - it's cheaper and easier to replace than a window.
2. Connect jumper cables to the battery terminals under the hood.
3. Try to unlock the door using the key remote.
Megalocnus is offline   Reply With Quote
Old 01-11-2017, 02:53 AM   #3
AbdullaJaafari
My Ride: E46 330ci
I'm going to first change the batteries in the keys and check again, if that doesn't work, I guess I'll be losing the grille (Much better than losing a window). Just found this video to see how I can unlatch the hood:
Old 01-11-2017, 05:04 AM   #4
Megalocnus
Actually the diamond-shaped key is difficult to open - cutting is involved and there is a decent chance to damage the circuit board or the RFID element. Replacing the rechargeable battery itself is not trivial since it involves soldering, and few people can do that without overheating the battery in the process.
I think that in your particular situation it's preferable not to mess with the key.
Old 01-11-2017, 07:17 AM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
The key battery is rarely a problem.
Since the door lock link is broken, chances is the GM5 may be bad, but did the keyfob ever work to unlock the car?
Do the interior lights come on when the keyfob is used to unlock the car?
Often a weak battery can cause a questionable GM5 to not unlock the car.
Old 01-11-2017, 07:37 AM   #6
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
a friend of mine had the same problem,
he solved by inserting a metal wire with a hook at the end (paracord), through the window seal in the direction of the passenger's handle
it's a PITA to aim that, but after 1hr of trying, he was in
lube the wire to make it slide easier
good luck
TheRiddle is offline   Reply With Quote
Old 01-11-2017, 08:06 PM   #7
Renboy
My Ride: 04 330Ci '08 Daytona
^^^ That.
But, if you can, get an arm cuff that's used to measure blood pressure. Carefully put it between a door window and the seal. Then pump it up a bit so that you bend the window away from the seal. This will give you more space to work with so that you can unlock the car.
Renboy is offline   Reply With Quote
Old 01-11-2017, 11:52 PM   #8
Swiff
My Ride: 2002 330xi
Does the trunk open with the key. If the battery is dead. you can boost it .
Swiff is offline   Reply With Quote
Old 01-12-2017, 04:55 AM   #9
AbdullaJaafari
My Ride: E46 330ci
For some reason I have these old keys and not the diamond shaped ones.
Old 01-12-2017, 04:57 AM   #10
AbdullaJaafari
My Ride: E46 330ci
When I first got it, it worked just fine as long as the key is very close to the car, like extremely close and yes the lights did come on then
I've been trying to fiddle with the car for the past 2 days but with no results.. although twice while I was trying to open it, the interior light came on and dimmed out..
Old 01-12-2017, 04:58 AM   #11
AbdullaJaafari
My Ride: E46 330ci
Originally Posted by Renboy View Post
^^^ That.
Unfortunately the top of the window is under the seal/window frame and there's no way I can pry it open, and yes I did try the pump cuff thingy ..
Old 01-12-2017, 04:58 AM   #12
AbdullaJaafari
My Ride: E46 330ci
The idiot before me installed a reverse camera in the place of the trunk's keyhole.
Old 01-12-2017, 05:00 AM   #13
AbdullaJaafari
My Ride: E46 330ci
Day 3, and I still can't access my car in any way ..
I broke the front grill so I could attempt unscrewing the hood bolts, but none of my tools worked, and I couldn't find the right tool anywhere..
I'd really hate it if I need to break the window..
Old 01-12-2017, 05:25 AM   #14
du80is
My Ride: E46 330Ci
Here is a long shot. I have an aftermarket key a diamond one. But most people couldn't tell it from oem. Some of these keys can be set to either frequency and sometimes this happens if the key is jammed in my pocket. I.e. Goes from 315 to 433 MHz and doesn't work anymore. I have to go through a key pressing sequence to get it back. Then it opens the door.
Does the led flash when you press the key?
du80is is offline   Reply With Quote
Old 01-12-2017, 05:27 AM   #15
du80is
My Ride: E46 330Ci
Also you could take it to a car key locksmith they can at least tell if it's transmitting. If the battery in the key is discharged you might get some advise on inductive charging outside the car. I've read sometime trying a toothbrush charger.
Old 01-12-2017, 07:31 AM   #16
AbdullaJaafari
My Ride: E46 330ci
My car came with the old key (pre-diamond)
But not sure about the frequency and I'm sure noone around here would be able to do a frequency test on the keys
I'm gonna try and take off the bumper today and see if I could reach the hood's cables or even the latch
Old 01-12-2017, 08:14 AM   #17
Dogthebountyhunter
My Ride: 02 325xi
Hey op why are you trying to get under the hood, the battery is in the trunk if your trying to test it or something. Also you have two different keys obviously maybe one is for the trunk only considering the old owner messed up the key hole.
Dogthebountyhunter is offline   Reply With Quote
Old 01-12-2017, 08:30 AM   #18
sammy9010
My Ride: 01 330ci vert
Had a similar problem with my diamond key. It wasnt charging while the car was on anymore and i broke my tumbler my drivers side (330ci vert so only one key hole). From what i gathered while trying to get my car unlocked, the battery in the fob fails easily. Luckily, if you can get it open with a razor knife you can replace the battery and solder in a new one.
sammy9010 is offline   Reply With Quote
Old 01-12-2017, 08:32 AM   #19
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
I believe the situation is that the car's battery is low or dead and he wants to access the jumper points under the hood to supply power.
He cannot get into the trunk because its lock was replaced with a backup camera installation.
The coupe is pretty easy to break into because, unlike the sedan, the driver's side window doesn't have a metal frame at the top and the window can be flexed out enough to slide a thin tool in the gap.
The larger key shown in post #9 is not original while the smaller one might be original but doesn't have the wireless fob.
///Mmmmmm...
Old 01-12-2017, 08:43 AM   #20
Dogthebountyhunter
My Ride: 02 325xi
Makes sense I forgot about the jumper points under the hood. Any one know what the blinking red light is called by the radio. Maybe op can see if his is blinking.
