Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 244 votes, 5.00 average. Display Modes
Old 04-27-2016, 12:42 PM   #701
330XiNamedBif
My Ride: 2005 330Xi 6-speed
Originally Posted by dan4081 View Post
Just a couple of things to point out.
1 There is a dedicated thread right on this page for the Eonon unit you bought and installed. You posted your post in the D5150 thread instead of the GA5150F thread. Post over on the correct thread and some of us with the GA5150's will be able to help you better.
2 You do NOT have to have a hotspot running to use GPS if you are using any one of many different GPS programs that are designed to run offline. I.E. Igo, Here, Google Maps, and some others. Just download the appropriate map to your unit and use the GPS in offline mode. Really works well.
Any other questions or concerns and I'll try to help...
My apologies for posting in the wrong thread. It seems I got a little hasty in my frustration. Can you please explain how I can run Google Maps without my hotspot active? I get an error message and cannot successfully input an address unless my hotspot is live. The tech from Eonon treated me like a real idiot when I told her I assumed it would work without hotspot. Maybe they've changed that function?
2005 330Xi 6-speed with Sport, Cold Weather, and Premium Packages. Titanium Silver/ Black leather, myrtle wood interior trim.
330XiNamedBif is offline   Reply With Quote
Old 04-27-2016, 01:03 PM   #702
dan4081
My Ride: 2000 323i
You have to have the maps for the area you are using downloaded to the unit before you can use it offline.
On my unit I am using HERE GPS (Free BTW) and I had to hook it up to a hotspot, download the program and maps, and then it can be used with out a hotspot just like a standalone GPS unit.
Google Maps works the same. Hook up to your hotspot, download the map for the State you are attempting to use it in and then set it for offline use.
BTW, heres the correct thread:
http://forum.e46fanatics.com/showthread.php?t=1079029
Page 26 has some offline GPS suggestions and instructions on how to set them up.
dan4081 is offline   Reply With Quote
Old 04-27-2016, 01:09 PM   #703
330XiNamedBif
AWESOME Thanks!
Old 08-25-2016, 08:02 AM   #704
lgv10
My Ride: 2004 BMW 330ci
Eonon D5150vu resetting itself to factory
Hey guys,
I have been following your posts relating to the Eonon D5150 and I decided to purchase one for my 2004 BMW 330ci. I had to buy the extension for the trunk boot. I was able to install everything and it seemed like the radio was working fine. However, I noticed that every time I restart my car, it resets all of the settings I made to the radio. It erases all of my radio stations and other settings. Did I wire something wrong? Does the extension cable supply a continuous source of power to the unit or does some additional wiring need to be connected? There is a "blue illumination" wire that is attached to the extension cable. Do I need to connect that to keep the power source going to the radio?
I have been trying to get answers from Eonon but they are asking that I rip out the radio and send it back to them.
I can use some advice here guys.
Great forum by the way!
Thanks in advance!!!
lgv10 is offline   Reply With Quote
Old 08-26-2016, 01:30 AM   #705
EononCarDVD
EononCarDVD's Avatar
My Ride: BMW E46
Hi lgv, no worry we will try our best to help you. You can just PM us your Email, order No. or serial No. of the unit, we will help you check what we can help you further, thanks!
Top-notch Eonon Android Car Stereo. Change, why wait.
Welcome to check our cool new GA7150 BMW E46 Android 6.0 Car GPS with 12GB for Apps, more powerful and intelligent than ever!
14 Rounds of Group Buy have been arranged till now! PM me anytime if you'd like to join and save!
EononCarDVD is offline   Reply With Quote
Old 09-01-2016, 07:26 AM   #706
maxmansson
My Ride: 1999 320i
Hi!
I have a slight problem regarding installing a backup camera. Everything is hooked up and working except that when I shift out of reverse the headunit doesn't go back to the regular screen and just turns black. Do i need to connect the orange cable from the unit to something in the car?
maxmansson is offline   Reply With Quote
Old 09-01-2016, 07:26 AM   #707
maxmansson
My Ride: 1999 320i
Hi!
Old 12-05-2016, 04:34 AM   #708
cosworth89
My Ride: BMW 330ci coupe
Hi all sorry if this is in the wrong post but I'm a bit at a dead end, I've received my eonon d5166 but there is a cable that is cut from the canbus box to the main harness its the grey cable and I have no idea where it splices into the wiring harness I've actually got to hardwire the whole unit into the BMW wiring as there is no connector block on the eonon wiring harness its all been cut it will be going in to my e46 330 coupe with the business CD player so won't need the 5m extension harness,
cosworth89 is offline   Reply With Quote
Old 12-08-2016, 08:31 PM   #709
EononCarDVD
My Ride: BMW E46
Hi cosworth89, no worry we will try our best to help you. Please kindly tell us your Email, order No. or serial No. of the unit, we will help you further, thanks!
Old 01-24-2017, 02:20 PM   #710
topazblue330ci
My Ride: 2002 BW 330ci
Volume Output Level to High for BMW AMP
The Eonon audio output voltage level is high for use as an input to the BMW / Harman AMP in the trunk, so even the lowest volume level is kind of high. Easily attenuated by putting a 1K-ohm resistor in series within each or the 4 positive output wires. High volume levels are still all you would ever want.
topazblue330ci is offline   Reply With Quote
Old 03-02-2017, 08:28 AM   #711
darknights
My Ride: 2004 BMW 325ci coupe
very nice write up! I was going to just go with a flip out screen until I saw this!
darknights is offline   Reply With Quote
backup camera, bluetooth, business unit, navigation
