Heat only hot while driving. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-20-2013, 06:13 PM   #1
cincy87
My Ride: 2000 323i
Hello everybody I am new to the group. I have searched old threads but just couldn't find exactly the answer I was looking for. I have a 00 323i my heat only gets hot when I accelerate, The anti-freeze is full and the car only over heated one time I have left it just sit and idle with heat on and off a few different times and it never overheats. Any help would be greatly appreciated its starting to get cold out lol. Thanks in advance.
cincy87 is offline   Reply With Quote
Old 10-20-2013, 06:21 PM   #2
Guest021715
Account closed.
First, properly bleed your cooling system, and verify there aren't clogs in your heater core.
Second, check the headgasket.
Old 10-20-2013, 06:28 PM   #3
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
Check your expansion tank for damage and make sure your coolant level floater is there. If its damaged, there's a decent chance a part of it got stuck in the heater valve, and possibly some in the heater core. Bleed your system on an upward slope.
-Chris
chris98891 is offline   Reply With Quote
Old 10-20-2013, 06:43 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Also verify your thermostat is not weak.
See 3rd link below in my signature. Just because the coolant temp gauge is in the center, does not mean the engine is running at the proper temperature.
Old 10-20-2013, 07:03 PM   #5
orb
My Ride: 325Ci
Soft failing thermostat?
orb is offline   Reply With Quote
Old 10-20-2013, 07:32 PM   #6
cincy87
My Ride: 2000 323i
Re: Heat only hot while driving.
Thanks for the fast replys. I do have the floater and it is reading full, but I will definitely try bleeding the system and check expansion tank.
Sent from my VS840 4G using BimmerApp mobile app
Old 10-20-2013, 07:35 PM   #7
cincy87
My Ride: 2000 323i
And if it is thermostat how bad of a job is it on these cars? This is the first BMW I have owned I'm not familiar with them at all. They are definitely a breed of their own.
Old 10-20-2013, 07:37 PM   #8
cityjohn
My Ride: 2001 M3
Do your wipers slow down when you give it gas? Just kidding, sounds like the 1940s all over again.
cityjohn is offline   Reply With Quote
Old 10-21-2013, 10:15 AM   #9
J-SON
My Ride: 2002 Volvo V70 XC
Thermostat. Mine failed enough for the car to get luke warm while driving, but not enough for good heat. Of course you know it failed while I'm about 20 minutes from Canada in January...
current rides (my wife and I):
2002 Volvo V70 XC Cross Country Wagon, 2004 Volvo V70R, 1985 Buick Regal Grand National, and My Desk.
J-SON is offline   Reply With Quote
Old 10-21-2013, 11:49 AM   #10
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
...and make sure the little dial in between the center vents is all the way to the red dots not the blue dots.
Schlag96 is offline   Reply With Quote
Old 10-21-2013, 11:51 AM   #11
Brinkley
My Ride: 99 328i, 07 z4 3.0
You have a leak somewhere. That has led to air in the system, which always finds it way to the heater core. Investigate, find leak, fix.
Brinkley is offline   Reply With Quote
Old 10-21-2013, 12:07 PM   #12
cincy87
My Ride: 2000 323i
Brinkley that's exactly what is going on I just found the leak on my lunch break. Thanks a lot for the answer though I didn't know that small leak would create this much of a problem haha
Old 10-21-2013, 12:16 PM   #13
Berserker323i
My Ride: 1999 323i 4door 5sp
Your water pump could be failing. One of the main problems for bmw is the cooling system. I would say replace water pump and thermostat
Berserker323i is offline   Reply With Quote
Old 10-21-2013, 12:19 PM   #14
jfoj
Very common, but hard to locate leak is with the O-ring on the temperature sensor in the lower radiator hose. This O-ring needs to be replaced anyway, no tools needed. Just pinch the release tabs on sensor when the car is cold and remove. Very little coolant will leak out.
If there is any moisture on or under the sensor on the lower engine cover, the O-ring is leaking.
O-ring part number is below in my signature.
Old 10-21-2013, 12:33 PM   #15
cincy87
My Ride: 2000 323i
I think leak is on the top radiator hose. Will find out for sure after work.
Old 10-21-2013, 12:46 PM   #16
TopasE46
My Ride: 2001 325Ci
Ha. I think this went over everyone else's heads.
TopasE46 is offline   Reply With Quote
Old 10-21-2013, 06:08 PM   #17
cityjohn
My Ride: 2001 M3
Yeah no more vacuum accessories, remember Mercedes doorlocks and Lincoln headlamp doors?
Old 10-21-2013, 06:18 PM   #18
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
It only overheated one time? Did you do anything after that happened? And when did it happen.
You didn't say mileage...might want to do more than just fix the one leaking spot while you have system open.
Therm is easy to do...but read mango's sticky and about 5 other cooling threads until you puke and feel cold inside. Read, read, puke, read, read, puke, read, spam, spam, eggs, and spam.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 10-21-2013, 07:14 PM   #19
cincy87
My Ride: 2000 323i
It overheated once and I didn't do anything I turned car off for awhile and hasn't done it since. And I just turned 190k
Old 10-21-2013, 07:18 PM   #20
dmax
dmax's Avatar
Next time it overheats, you need to do something...don't forget.
Hopefully you'll fix it this time. Lose your cooling system, lose your engine, pay more than the car cost to fix it...or read the cooling threads and fix your car. Read and puke...don't forget that either!
dmax on Facebook
Mangofy your E46!
323i, heat
