Thread Tools Search this Thread Rating: Thread Rating: 358 votes, 4.97 average. Display Modes
Old 11-14-2016, 07:58 AM   #641
M Shandy
My Ride: 02 325i base
So as of now here is the scoop I opened the tank and checked Tue fuel pump it's working fine :: new walbro 340lph :: I have plenty of fuel at the rails I was able to jump the starter to verify that the ground to engine and power to starter is all ok however I have no spark with leads me to be live that I am not getting power either due to the ignition switch or ews?... the switch is easy enough to build and try but after that... also I checked over fuses even the ones in the dme housing
M Shandy is offline   Reply With Quote
Old 11-14-2016, 08:00 AM   #642
M Shandy
So my wonder is if the switch is not the culprit would simply buying a dme with the ews deleted bypass all the other crap ? The antenna the key chip and so on. I have wanted to get one for my lightweight flywheel kit and intake exhaust upgrage and sap delete
Old 11-14-2016, 08:15 AM   #643
M Shandy
Also it is about fifteen minutes from my house behind a restaurant so checking on thing is tough to do so when I go there I want to have a list of possible things to check on i am working on getting a trailer to tow it home
Old 11-25-2016, 09:54 PM   #644
Chocolate Lab
My Ride: 2000 328i black 5-sp
My no-crank problem was the EWS... took the dealer a while to figure it out and I let him fix it.
Then not one week later, I have a crank-like-crazy no-start problem and the car won't start. Fuel pump is barely a year old and was from OEMbimmerparts, so I know it was a good brand and not junk.
Guess the next step is to try the fuel pump relay? Got the glove box out but in the lousy light I couldn't figure out how to get to it. I guess you have to remove more because there's no way people can get their hands in there to just pull it out. (And does it just pull straight out, or is there a clip on there I couldn't see?)
Forgot to ask: Even though it's a totally different type of no-start, could this be related to my no-crank problem the dealer fixed? Could be a total coincidence but maybe not.
Chocolate Lab is offline   Reply With Quote
Old 12-06-2016, 08:24 PM   #645
M Shandy
sorry that I have not been able to give my two cents but it's been a few weeks since I had a break down no crank no start condition, I got it towed to a local indie who after hooking up their computer told me they thought it was simply the key? However they could not be certain.so for 180$ I had one sent up from Connecticut next day so when they got it voila starts like always, but for whatever reason my old key is working fine now?.... I am going to get a second ecu that has the ews deleted and some other modifications. I need to just suck it up and buy one of those ebay BMW laptops.
Old 12-06-2016, 08:26 PM   #646
M Shandy
Hey SCOTIA54 is that where you live? I am not to far from the Albany area
Old 12-21-2016, 09:44 AM   #647
ant318ise
My Ride: e46 318i se
I have no earth switching at the fuel pump relay terminl 85 from the dme fuel pump and relay tested and are good any ideas would be greatly apreciated thanks
Sent from my SM-G930F using E46Fanatics mobile app_nr_
ant318ise is offline   Reply With Quote
Old 01-08-2017, 11:53 PM   #648
Clrios
My Ride: 323ci 2000 bmw
I have a2000 323ci BMW that will not start. It had been sitting up for two years and I tried using my regular key and it would not crank then I used the master key and it started Right up. I have been driving it for abt three weeks and the other day I got in it to crank for work and it would not start. No clicking everything lights up, all doors lock and unlock. Going to see if I can test my key. Bought a battery for it, that's not it. Any suggestions please.
Clrios is offline   Reply With Quote
Old 01-09-2017, 11:55 AM   #649
Clrios
E46 no start
So I was told it's not the key. So I have to pay 125. To see just what it is. I don't know what to do.
Old 01-09-2017, 10:47 PM   #650
Clrios
I am trying to get a new key because my car won't crank but has power everywhere else. I pray this is the problem. How long did it take you to get your key?
Old 01-10-2017, 09:54 AM   #651
Chocolate Lab
Key/ews communication was the problem on mine. Dealer had my new key in just 2-3 days. That didn't fix the problem, though -- I needed a new/reprogrammed EWS.
You said in post #649 you were told it's not the key, but now you think maybe it is?
Old 01-10-2017, 10:09 AM   #652
Clrios
Well I think it is the key cause of it sitting in my garage for almost two years and it did the same thing it is doing now so I used my old key and it started. I now can not use either key. I know it can't be the starter because it has charge and power, just no turn . I am going to the dealer tomorrow to get a key. I pray this works because I do not have the money to put in shop. When you got your key, what all did they do?
Old 01-10-2017, 10:18 AM   #653
Chocolate Lab
What did they do? They just gave me the key. At the time my car was stuck at home (wouldn't start) so I had to program it myself.
Maybe yours is the EWS like mine. That's what happened to me, the key worked and then it just stopped one day. I have a 2000 like you -- that's so old I guess stuff just stops working sometimes.
Old 01-10-2017, 10:34 AM   #654
Clrios
Yeah I know they are old. I hope I can just get the key and it all works but if not I'll have to do what I have to do. Thank you for the info. Programming it is only locking the doors and trunk correct? Cause I already know how to do that. I would like to ask you one more question if you don't mind. My DSC light comes on while driving and my right brake will pulsate a little do you know why that is? I can be going 60 and it will do it or going slow.
