INPA: Reading shadow memory error - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 08-23-2014, 03:53 AM   #1
Hazey82
My Ride: M3
Hi guys
Installed and configured INPA. Everything seems to be working except when trying to Read shadow Memory I am getting this error:
API ERROR
ApiFsLesen/apiResultSets: API ERROR Nr. 98
SYS-0008: JOB NOT FOUND
Job error or no such result !
Continue script processing ? YES NO
I cannot find anything on the net. Thanks
Hazey82 is offline   Reply With Quote
Old 08-23-2014, 06:00 AM   #2
Davconelectric
My Ride: 2 dog powered sled
Could be the smg. I hear their ****
Davconelectric is offline   Reply With Quote
Old 08-23-2014, 06:09 AM   #3
Hazey82
My Ride: M3
Helpful cheers will try that out!
Old 08-23-2014, 06:11 AM   #4
CortinaD
My Ride: lots
What version of inpa and daten files?
CortinaD is offline   Reply With Quote
Old 08-23-2014, 06:18 AM   #5
CortinaD
My Ride: lots
He wasn't stating anything we didn't already know.
Are you trying to read the error logs on your SMG DME?
Old 08-23-2014, 06:18 AM   #6
Hazey82
My Ride: M3
My download of INPA was 6.4.3 but within the program About shows 4.4.70.
Daten files, couldnt tell you mate
Cheers
Old 08-23-2014, 06:23 AM   #7
CortinaD
My Ride: lots
from the edibas manual
EDIABAS first checks whether the job specified in the apiJob call can be found in VARIANTE.PRG. If this is the case, the job is executed. If the job does not exist in VARIANTE.PRG, search is continued in the first alternative basic ECU description file specified in the header from VARIANTE.PRG following uses, here BASIS1.PRG. Search is continued accordingly until the job is found. If the job is also not found in the last ECU description file (here BASIS.PRG), EDIABAS issues the error message "SYS-0008: JOB NOT FOUND".
Old 08-23-2014, 06:25 AM   #8
Hazey82
My Ride: M3
No on the Engine. Selecting S54 I get version error which research says in normal? Then I get the API error selecting read shadow memory
Old 08-26-2014, 09:55 PM   #9
Hazey82
My Ride: M3
I downloaded V41 daten files and put them all in the correct locations. Still same problem
I noticed there is a Data folder on the daten iso which has sub folders of all the different engines or maybe its the DME, one of them being the MSS54 which contains a heap of 0PA & 0DA files.
No idea if this is what it needs or where to put them
Old 08-26-2014, 09:55 PM   #10
Hazey82
My Ride: M3
Old 08-26-2014, 10:17 PM   #11
CortinaD
My Ride: lots
you would have the mss54hp
inpa
