Old 10-03-2014, 03:37 PM   #1
one_off
My Ride: 325i
Unable To Locate Fuel Pump
After Doing Research On The Location Of The Fuel Pump On My 2003 E46 And How To Change It, To My Surprise After Removing The Metal Lid That Covers The Fuel Pump Shown On The Videos And Diagrams, Found The Fuel Pump Completely Unaccessible, Meaning I Did Not Have Direct Access To It.
There Is A Piece Of Steel Which Seems To Be Part Of The Frame, Can Somebody Please Let Me Know If The Gas Tank Has To Be Dropped ?
I Already Have The Pump However The Access And The Connection In The Car To The Pump Are A No Match To All The Videos.
one_off is offline   Reply With Quote
Old 10-03-2014, 03:42 PM   #2
cityjohn
My Ride: 2001 M3
This is a different year car but basically the location is the same. Just take out the seat bottom and remove the metal covers.
cityjohn is offline   Reply With Quote
Old 10-03-2014, 03:54 PM   #3
Phrygian
My Ride: 2000 323i
Please take a picture of what you're talking about and post it.
Phrygian is offline   Reply With Quote
Old 10-03-2014, 04:02 PM   #4
Yewzer B Lewzer
My Ride: 2003 325i
Do you have a SULEV?
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 10-03-2014, 04:15 PM   #5
jfoj
My Ride: 330CiC, M5, X5
I was just going to ask the same question.
2003-2005 325i in CA is likely a SULEV M56 car.
Simple to figure out, look under the car and see if you have a black plastic fuel tank or a stainless steel fuel tank.
If stainless steel, the fuelpump/tank is about $6000, and no this is not a typo.
Hopefull you have less than 150,000 miles on the car, then it is covered under warranty, however, you will have to fight with the dealer as they likely do not understand the SULEV warranty.
http://forum.e46fanatics.com/showthr...ighlight=sulev
Old 10-03-2014, 04:29 PM   #6
cityjohn
My Ride: 2001 M3
Totally forgot about this possibility. Makes sense.
Another way to check:
Old 10-03-2014, 04:36 PM   #7
jdstrickland
My Ride: '94 325iC & '00 323i
What did you do?
The sound insulation can be pulled aside to reveal the covers, you are not supposed to cut anything to get to the fuel pump or the fuel level sending unit.
Old 10-03-2014, 04:38 PM   #8
jdstrickland
If the fuel pump is not where it is expected, then you probably have the SULEV. If you need fuel tank service with this model/option, then it is probably under warranty.
Old 10-03-2014, 04:50 PM   #9
one_off
My Ride: 325i
Will Check Into The SULEV Warranty.
Likely My Car Is An M56 Due That There Is No Direct Access To The Fuel Pump And Have Learned The Fuel Pump, Fuel Filter And Fuel Tank Are All One Component.
Thanks For The Info.
Old 10-03-2014, 04:59 PM   #10
one_off
My Ride: 325i
Thanks.
My Car Has The SULEV Displacement.
Old 10-03-2014, 05:51 PM   #11
jdstrickland
Is your pump dead, or are you just trying to be proactive and replace a $150 part before it goes south on its own?
Old 10-03-2014, 05:58 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by jdstrickland View Post
What did you do?
I ripped out all of that crap from the back of the car.
Old 10-03-2014, 06:18 PM   #13
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You're crazy. I just spend a few hundred bucks to put insulation in my subaru. I couldn't imagine ripping it out.
Old 10-03-2014, 06:20 PM   #14
eneka
My Ride: 2003 325i
Thanks.
I see you're in the SGV, I am too, if you're still under warranty, I'd highly highly recommend Crevier BMW, it is quite far but they are way better and much more knowledgeable about the warranty than Assael/Monrovia and New Century BMW.
eneka is offline   Reply With Quote
Old 10-03-2014, 06:21 PM   #15
golf_234
My Ride: E46, E90, F30
SULEV. OP, as said, you, have a 15 year/150,000 mile warranty on your emissions related components. So, if you are under 150,000 miles, you are covered. The dealer is going to have no idea what you are talking about, so go in with the warranty info, and clearly know what is going on prior to going in, if necessary contact BMWNA, in fact, probably contact BMWNA prior. There is a PDF floating around the internet that discusses the E46 SULEV warranty. Definitely print this out. If you are over 150,000, one user on the forum has successfuly retrofitted a standard fuel system into the car. But not advocating messing with any emissions related components for street use, because that would be illegal. Also, are you sure it is the fuel pump that is the culprit? Crank but no start? Check the pump relay first. Also do you hear a buzzing when you turn the key to position 2 prior to starting? If relay is fine, and no buzz is heard, then yes, very likely the pump.
golf_234 is offline   Reply With Quote
Old 10-03-2014, 06:22 PM   #16
golf_234
Love Crevier!
Old 10-03-2014, 07:26 PM   #17
one_off
My Ride: 325i
Pump Is Still Running, However Car Is Misfiring.
Had A Car Before Where It Kept Misfiring Like My Car Is Doing Right Now And It Happened To Be The Fuel Pump.
Old 10-03-2014, 07:27 PM   #18
cityjohn
My Ride: 2001 M3
Do you have the All Cap App
Old 10-03-2014, 07:31 PM   #19
one_off
My Ride: 325i
Car Sometimes Does Not Start On The First Turn Of The Key, Will Have A Start After I Turn The Key On The Stand-By After I Wait A Few Seconds And Will Start With No Hesitation. Car Is Now Misfiring, Has A Major Loss Of Power And Idles Hard.
Old 10-03-2014, 07:33 PM   #20
Yewzer B Lewzer
My Ride: 2003 325i
Misfires can be other things too such as vacuum leaks.
I've been wondering something: can a SULEV car be retrofitted with a non SULEV tank and fuel pump?
fuel, fuel pump
