Convertible Top Retracts Too Slow :( - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 06-04-2016, 01:26 AM   #41
taylor192
My Ride: 2003.5 M3
Check the:
1. fuses. There are several for the top.
2. Relay. It's above the pump somewhere. There's a couple great threads on how the relay fails, how to test it (swap with another), ...
Old 06-04-2016, 02:53 AM   #42
masCh
My Ride: E46 Convertible
I bought my rebuilt pump at roofmotors.co.uk
I am unaware about "the green electrical plug at the top of the pump". Where does it go to? I have not seen such a connector.
Edit:
I found the "green connector" but it is a solenoid connector right?
There are two solenoid connectors..
So in total:
2 solenoid connectors
6 hydraulic lines
4 motor connectors
masCh is offline   Reply With Quote
Old 06-04-2016, 03:02 AM   #43
masCh
Originally Posted by taylor192 View Post
Check the:
I noticed a relay on a bracket, I think this is the one. But I don't know where it goes. Ok I will give that a check.
Old 06-04-2016, 09:06 AM   #44
taylor192
My Ride: 2003.5 M3
Edit:
So in total:
6 hydraulic lines
4 motor connectors
Just to be clear, you bought a rebuilt pump and did not get your pump rebuilt.
Are you sure they are the same pump? There are 2 variations of the pump. Klaus wrote a post on this, search to find it.
Old 06-04-2016, 09:10 AM   #45
masCh
Yes that is correct, bought a rebuilt pump, I could never get my own pump rebuilt by sending it overseas to UK or US.
They are the same part numbers, could there be variations if the part numbers are the same?
Old 06-04-2016, 03:16 PM   #46
klixtokw
My Ride: bmw 325 ci
Pump
yOU NOW NEED TO TAKE CARE OF YOUR PUMP. CONTACT Klaus pump rebuild. Link on this forum.
Thanks, I have them looking like your photos now. Still the motor makes a sound but nothing is happening with the top.
klixtokw is offline   Reply With Quote
Old 06-04-2016, 03:27 PM   #47
klixtokw
My Ride: bmw 325 ci
Relay on bracket
Picture attached may help.
Name:	DSCN3198 (Medium).JPG
Old 06-04-2016, 04:59 PM   #48
taylor192
My Ride: 2003.5 M3
I don't recall. Hopefully it's easy to search and find.
I remember the pumps look different. The older pump has extra parts.
Old 06-04-2016, 08:16 PM   #49
masCh
The pump looks exactly the same every single bit except the colour of the oil inside. The older one is almost black, whereas the new one is transparent.
The old pump doesn't make a sound at all. The new one makes a buzzing sound when I press the two top-up and top-down buttons at the dashboard.
The relay bracket in Klix's picture I know where to find it, its just hanging there in the trunk. I will test that today once I find out what its called so that I understand the pin outs.
convertible, diy, slow, top
