Sponsored by BAVSOUND
Old 09-16-2015, 10:48 PM   #21
Rockyyy
My Ride: 325ci
I have the Grom in the dash unit. It works very well. Connects right away, works with the steering wheel buttons and is totally stealth. Would definitely recommend it
Rockyyy is offline   Reply With Quote
Old 09-17-2015, 02:00 AM   #22
ralf
My Ride: 330i
I installed this in my car:
Blackberry Music Gateway: Sound goes through the aux connection. It connects and disconnect every time I turn on and off the car. When the car is turned off the music stops in the phone (iphone) when I start the car again I have to press play in the phone to resume music which is not a bad thing.
I got a usb power adapter an taped a power and ground cables in the back of the radio so I could use the bluetooth streaming even when the car is turned off.
Installation was easy: Tap 2 wires behind the radio, connect usb power cable to bluetooth dongle, connect audio cable to aux in. I tucked everything behind the glove box after pairing my phone and never needed to touch the bluetooth adapter again.
The good: Cheap solution. Music is crystal clear, good quality bluetooth adapter, had it for more than a year without issues.
the bad: you have to change tracks in the phone. No stereo or steering wheel control. The sound notifications go through the bluetooth connection even when you´re listening the radio for example, so you can miss something.
Links to products:
http://www.ebay.com/itm/BlackBerry-M...item58c8f127f4
http://www.ebay.com/itm/Mini-USB-12v...item1a0099edb3
ralf is offline   Reply With Quote
Old 09-17-2015, 02:55 AM   #23
mbt28
My Ride: BMW 2002 318Ci Conv.
Hello,
Best solution will be using wt32i from bluegiga and arduino mega to emulate cd changer. If you use isolated dc dc converter for bluetooth device, you will have pure sound. However for this you need take out your head unit on bench to work on it.
Within that you can program it as you like.
mbt28 is online now   Reply With Quote
Old 09-17-2015, 09:44 AM   #24
ralf
My Ride: 330i
Can you explain this solution in more detail?
Originally Posted by mbt28 View Post
Hello,
Old 09-17-2015, 12:01 PM   #25
mbt28
Hi Rulf,
Sure, if you are handy with arduino, you can connect it to ibus line and fake the cd changer. Then with using any sound chip you can transfer sound, and send AVCP commands according to ibus commands of steering wheel and radio buttons.
Sounds simple but need some good coding skills.
Old 11-11-2016, 12:00 PM   #26
Dongotti
My Ride: 330i
I hear you on that Grom. I really want to know what the sound quality is like? Is it CD quality or is it more muffled? Also are you listening over BT, USB or Aux?
Dongotti is offline   Reply With Quote
Old 11-11-2016, 09:01 PM   #27
Rockyyy
My Ride: 325ci
I'm listening with BT. I have zero complaints about the sound quality, it's definitely not muffled at all. More than sufficient to play music from Spotify. I dont know if any bluetooth system can match cd quality but its close enough that i cant tell the difference. My only complaint about it is it has minor bugs from time to time. Sometimes I have to push pause and play a couple time to get audio but it's rare. These might have been fixed on more recent firmware though. After using it for two years I can say it's not perfect but the pros of how well it integrates with the stock head unit and the steering wheel controls outweigh the cons of a couple minor bugs.
Old 11-12-2016, 12:24 AM   #28
Dongotti
My Ride: 330i
Appreciate the feed back, I will be biting the bullet in a few weeks. I came across LaPower on another thread but it looks too good and cheap to be true . Just afraid of the inferior ebay products.
http://www.ebay.com/itm/like/121543181090?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252 F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D110544 474129_324272%2526itemid%253D121543181090%2526targetid%253D1 97639913609%2526rpc%253D0.22%2526rpc_upld_id%253D90506%2526d evice%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.c om%25252Fulk%25252Fitm%25252Flike%25252F121543181090%25253Fl pid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526googl eloc%253D9027746%2526poi%253D%2526campaignid%253D623606627%2 526adgroupid%253D32762312649%2526rlsatarget%253Daud-265069067476%253Apla-197639913609%2526gclid%253DCj0KEQiA9ZXBBRC29cPdu7yuvrQBEiQAh yQZ9G1M7M4Z0Qi5uXLvhfFK4Jrc-HWk3ZPQkddv3bag9YIaAhJt8P8HAQ%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1122511598790&ul_noapp=true
Old 11-12-2016, 01:53 AM   #29
Rockyyy
My Ride: 325ci
Ya those are hit or miss. It might be alright but you won't find out until it's installed.
Old 11-29-2016, 07:03 AM   #30
Dongotti
My Ride: 330i
Best solution for BT streaming?
Got the Grom yesterday and will install it today. Will post some feedback on how it sounds. Mine only has BT functionality as I got the wrong cable to add aux support
E36 328is 5 SPD
E46 330i 5 SPD Sports Package
Old 12-07-2016, 07:05 PM   #31
L1011tristar17
My Ride: 1999 328i
I used the Denison unit for my car to go with the stock radio and so far I have no complaints. I use bluetooth through a 30-pin adapter on the iPod cable (which is hidden behind the dash). The first adapter I bought didn't work with my phone for some reason but the second one (different brand) works great and pairs every time.
L1011tristar17 is offline   Reply With Quote
Old 01-26-2017, 09:08 PM   #32
sroberts
My Ride: 2000 323ci
Are there any reviews for the $78 Ebay unit? http://www.ebay.com/itm/Bluetooth-Mu...-/121543181090. It does not seem to have a brand name which makes it kind of hard to search for reviews. But over 150 units have been sold.
sroberts is offline   Reply With Quote
Old 02-08-2017, 11:33 PM   #33
ralf
My Ride: 330i
I found this to be the best solution:
http://forum.e46fanatics.com/showthr...etooth+mki9000
Better than other adapters and with a really good car phone system.
Old 03-14-2017, 02:57 AM   #34
ZHPOWER
My Ride: 2003 ZHP
how much did it cost?
/// 2003 ZHP 6 Spd Manual / ZHPOWER Personalized Plate / 19x8.5 APEX ARC-8's /
H&R Sport Cup Kit / B&B Triflo Exhasut / OEM Euro Clears / Whalen Shift Machine /
35% Tint / Akebono Brake Pads / aFe Intake ///
ZHPOWER is offline   Reply With Quote
Old 03-18-2017, 10:45 AM   #35
Alibs555
My Ride: 2000 BMW 328ci
I wondered if anyone knows a central spot where you can see what radio "head" is what? And the year range? Which were Amped and which were not?
Let me explain my situation: My son has a 2005 325i. I ordered and successfully installed an "Anycar" Bluetooth/handsfee/usb/aux unit that works beautifully with his stock steering wheel etc. It plugs into either the CD or the AUX port in the back of the radio head. Some limitations in how it's used, but overall, good quality sound and great features for CAD$150.
About a month ago, I bought a 2000 328ci for myself...something fun, manual transmission to boot around in. Then I decided to order the same BT unit for my car. When I went to install it, I saw that the 2000 unit only has 1 AUX port, which seems to be plugged into an Amplifier in the trunk (I'm guessing, because I haven't traced it through the car, but there is a unit in the trunk behind the side carpeted panel). I know I don't have Harmann Kardon speakers.
By comparison, my son's 2005 has an AUX and a CD port. Since he doesn't have a CD changer or an "in-trunk" amplifier, the BT unit can be plug in either ports. If my memory serves my right, he has an Alpine unit. I know mine is a Blaupunkt unit.
1. Does anyone know if the Blaupunkt unit will work without the amp? I imagine not.
2. If I bought a used "newer" Alpine, will it work with my car?
3. How can I use the existing AUX port to plug in both the amp and the BT unit? Is there a "splitter" harness I can use?
4. Is there a stock unit year that is the Blaupunkt with both CD and AUX, that uses the Amp in the trunk?
Any thoughts would be appreciated. I have read over 200 posts and I'm stumped.
Thank you,
-Alibs555
...on the beautiful North Shore of Vancouver, BC Canada
Alibs555 is offline   Reply With Quote
Old 03-19-2017, 03:14 AM   #36
Alibs555
I thought to post a picture of the back of the radio head...it must be an older version as it only has one 10-pin plug, with only 5 pins...
Any thought how I can connect a Bluetooth unit?
-Alibs555
Old 03-28-2017, 10:47 AM   #37
Alibs555
Sorted it out. I had accidentally changed the dip switch settings on the BT unit during my install... All good now. Works a charm!!!
"Anycar" bluetooth unit...it works on all HU with roundpin plugs at the back. Look for it on eBay ...sold by SaxoBuy in Germany.
Excellent unit.
Happy motoring :-)
-Alibs555
Old 05-08-2017, 02:42 PM   #38
halo0
My Ride: '02 330i 5mt
For those of you with the Grom, does yours stay on all the time? The instructions have you tap into the constant 12V line and the unit is always on, even after I turn off my ignition my phone remains connected to the grom bt until I walk far enough away for it to disconnect. And if I walk back to the car it will reconnect! This doesn't seem right to me, I'm wondering about battery drain and also I have tasker tasks set up to run based off of the bt connection which this can mess up. Why did they do it this way?
Also, my Spotify hasn't been wanting to start playing automatically when I connect, is there a trick to this?
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 05-08-2017, 03:31 PM   #39
Dongotti
My Ride: 330i
I have those same issues, however it does turn off after a while. It will turn back on as soon as I press my key fob to open the door, then it will connect to the phone.
As for the trick to get spotify to play automatically, I don't have a solution really. What I been doing is using my iwatch to play the song in spotify. It beats me having to take out my phone and play the song manually.
E36 328is 5 SPD
Old 05-08-2017, 03:42 PM   #40
ZHPOWER
My Ride: 2003 ZHP
Everything will turn off after 15 minutes. Car goes into a battery save mode after 15 minutes. it occurs whether car is locked or unlocked.
30pin, audio, bluetooth, iphone, ipod
