Old 08-09-2015, 01:46 AM   #1
EuroSlovakiaE46
My Ride: Toyota Highlander
Oil cap blew off?!
Hello all, I own a E39 525i and we share the same motor M54B25, (most of us know this). I just recently rebuilt the VANOS unit and replaced the valve cover gaskets on my car. I performed an oil change with my buddy and he closed the oil filler when we finished filling the car. I double checked that it was screwed on and proceeded to drive the car the next two days. Long story short, the second day the engine was idling weird and the SES light came on. Lean at banks one and two. I figured that I may have had some type of vacuum leak and I proceeded to drive home after work. As soon as I got back, I opened the hood and the oil filler cap was gone. No where in the engine bay. I am completely baffled by this, and my only thought as to how this may have happened is that the crankcase vent valve is bad, and when I was driving on the highway, the increased crankcase pressure managed to shoot the cap off and disappear under the car. I have bought a new oil filler cap, and crankcase vent valve kit online. Absolutely no oil splattered in the engine bay, everything was dry. Anyone else have an experience of how a cap can just blow off and provide some insight? Thanks
I need an E46 to replace this Highlander!!
EuroSlovakiaE46 is offline   Reply With Quote
Old 08-09-2015, 10:11 AM   #2
markusmarkus
My Ride: 2001 330Ci
The oil filler cap wasn't properly secured. Period. These caps are way to meaty to be blown off by a bad ccv valve.
Old 08-09-2015, 11:03 AM   #3
EuroSlovakiaE46
I would say the same, but it was. After he closed it, he asked if he did it right and I physically took it off and rescrewed it into position. I'm wondering if the old cap itself was too loose or faulty, because the new cap I bought has a set of plastic tabs along with the metal ones and it holds super tight. I'm just afraid of driving the car because the pressure may find its way out somewhere else, like the dipstick tube, or back out through the new valve cover gaskets.....
Old 08-10-2015, 07:36 AM   #4
markusmarkus
My Ride: 2001 330Ci
The new cap will be fine. As I wrote above, there's no way that crankcase pressure can be high enough to blow a cap off.
Old 08-11-2015, 05:30 PM   #5
Gus-CO
My Ride: 323ci
Agreed... double checking you and your friend did didn't work. Cap was loose to begin with. No way it would come off by itself, or by excess pressure. For starters, there is only vacuum there unless lots of other stuff go wrong at the same time which is extremely unlikely. Even if there is increased pressure, that cap is not designed to do anything with it.. and will not just blow off.
Gus-CO is offline   Reply With Quote
ccv, e39, oil cap
