Old 10-14-2015, 03:30 AM   #41
HakenTT
My Ride: 323i with S54
Originally Posted by 328ijunkie View Post
Was, yes. After realizing they didnt exactly know fully what they were doing i was forced to jump into this rodeo (after a bout with TRM as well).
The factory vanos timing is less than perfect as is the fueling/timing. You are incorrect in your assumption that after 4K the vanos is locked in a fixed position, if you looked at the vanos tables you would see this. Removing safeties for the factory cats also leaves some on the table. You again still refute this yet have no evidence to the contrary. If it wasnt going to be immediately 'absorbed' by the MS43 master tuner, i would post logs of my flashes.
Factory vanos timing is perfect. There is nothing you can do there. Vanos tables show higher value at higher rpm, meaning any value for example above 200 is vanos turned off, so 202 and 215 are the same. There are no "safeties" above certain RPM, catalytic converters will not go bad because they are metallic, they don't melt.
Your dyno graphs are made by you, it is obvious that they are fake. Power increase is static from the beginning to the end. The fact that you got 10hp more at only 2000 rpm is a proof it is fake.
Your DISA polished tune is also fake. DISA valve is on/off, there is nothing you can do there other than change at what RPM is switches, and when it does airflow is disrupted within the manifold and you can't fix that with a tune. BMW had to introduce 3 stage DISA to be able to fix that problem but you were able to do it just with a tune.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 10-14-2015, 09:38 AM   #42
328ijunkie
My Ride: E36,E30
LOL,
I would be more than happy to send you the DRF's output from the dynojet that as far as i know cant be forged.
And the Vanos solenoids are PWM and are in crank degrees. It can vary precicely vary cam timing degree by degree not on off like a MS41 car. So If youre looking at the commonly distributed XDFs, ~85 is 'on' and ~126 is 'off'. Notice that there is a linear transition from on to off, This is as ive stated not ideal for maxium power.
And if cats dont go 'bad' or 'melt,' why are OEMs like BMW so worried about EGT's? Why do MSS54's MSS60s, MSS65s, have specific EGT maps that will kill power/enrich fuel to save/cool the cats down under sustained WOT conditions.
And the 'fake' DISA tune did require moving the DISA shutoff point (as you state it is off/on) to smooth the transition. A few hundred RPM, coupled with vanos changes makes all the difference.... Also 3 stage manifold was to help further increase linear torque across the board not to smooth a transition. Look at Dyno graphs of 330s/N51s they have horrible transitions....
Clearly Fake dyno runs :
328ijunkie is offline   Reply With Quote
Old 10-14-2015, 12:19 PM   #43
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Realize that all hakent is doing is Trolling everyone, for whatever reason he gets off on spreading bad information.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-14-2015, 01:18 PM   #44
328ijunkie
My Ride: E36,E30
Just to further illistrate your lack of info, BMW did not introduce 3 stg manifold to fix the 'bump' in the power band, if anything they made it worse as now theres more of them at ~3200 ~4200, and ~6200. They introduced it to further the flat torque curve.
Examples:
Old 10-14-2015, 01:30 PM   #45
328ijunkie
My Ride: E36,E30
And to further refute your 'fake' claim feel free to download WINPEP for free and open the DRFs and see for yourself all the data and progression 'Master MS43 Tuner'.
https://drive.google.com/folderview?...k0&usp=sharing
/donehere.
Old 10-22-2015, 03:36 PM   #46
jdjg
My Ride: e39, m52tub30
RK tunes
what do you guys think about Dinan say of the NA motors tunes?
http://www.roadandtrack.com/car-cult...anted-to-know/
jdjg is offline   Reply With Quote
Old 11-18-2016, 03:47 AM   #47
scorpionreptyle
My Ride: e36 330i
the numbers from the ignition and vanos maps ,how they corespond to degrees ? i need to understand they meanings raported to degrees,to play with increase /decrease overlap ,and advance/retard ignition somebody ..help !
scorpionreptyle is offline   Reply With Quote
330ci, m54, rk, tuning
