Old 11-03-2015, 03:22 PM   #1
Goli4thu5
My Ride: VW Golf MK3
E46 318ci - Head Gasket, CCV, M43B19
Hey guys. I have the opportunity to purchase a 2000 BMW 318ci. It's a car that has been parked up for a while due to what is apparently a bad head gasket.
I went to see the car today and found a couple of interesting things. The car did start and was just puring clouds of white smoke out of the exhaust. I pulled the spark plugs and all 4 were clean and dry. I also saw that the coolant level was decent however the car was low on oil.
It also seemed to have all of it's power ao I'm thnking that the head gasket/head might actually be ok. I was thinking the CCv system might be bad and that's why I'm here. Obviously it's not easy to tell without seeing the car but any help is appreciated.
Either way I am buying the car as the price is very good even if I have to part it out.
Also there is no sign of oil in the coolant or vice versa. Thanks!
Goli4thu5 is offline   Reply With Quote
Old 11-03-2015, 10:25 PM   #2
chanman1029
My Ride: 2003 325i
do it continue to smoke as the car runs, or does it clear up?
chanman1029 is offline   Reply With Quote
Old 11-05-2015, 08:34 PM   #3
mrbobmicjoe
My Ride: 2001 325i
Rent a compression tester from autozone or napa and make 100% sure its not the head gasket.
mrbobmicjoe is offline   Reply With Quote
Old 11-06-2015, 07:25 AM   #4
markusmarkus
My Ride: 2001 330Ci
OP is in Ireland.
Old 11-07-2015, 01:51 AM   #5
mrbobmicjoe
My Ride: 2001 325i
Originally Posted by markusmarkus View Post
OP is in Ireland.
oops my bad, but same advice either buy one or rent it from somewhere. Its worth the 30 or so dollars.
Old 11-08-2015, 10:50 PM   #6
JFM330i
My Ride: 2002 330i
Oil in the coolant is not the only symptom of a bad head gasket. It could also
have exhaust gasses in the cooling system causing it to over pressurize and over heat. I have had that with a e36 318i I had and my current 330i. Doesn't smoke at all and no coolant and oil mixing.
Did you drive the car or let it run for 20 mins?
2002 330i auto
1999 323i 5 speed
2013 Úlantra 6 speed
2010 rogue AWD
2003 eclipse GTS 5 speed
1995 celica st 5 speed
2007 gsxr 750.....track weapon!
JFM330i is offline   Reply With Quote
318ci, bmw, ccv, e46, head gasket
