Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 01-31-2016, 07:55 PM   #41
E46XITurboJoe
My Ride: 2001 330XIT Turbo
Originally Posted by Geo31 View Post
OK, just have a little patience with me. I think my copies are currently in storage (trying sell my house and build a new one).
no worries I am going to upload my fab notes from today to try to keep me on track now that people are taking interest
E46XITurboJoe is offline   Reply With Quote
Old 01-31-2016, 08:10 PM   #42
E46XITurboJoe
todays build includes this, with a threaded and vented aluminum cap and .1" thick walls currently drawing out the pieces to see how small of a plate I can order. bracket for this and the A/C relocation kit is laid out as well. no photos as its a cut a build type project
rough location before i start the new hard and soft pipe bends / placement
Old 01-31-2016, 09:37 PM   #43
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Why relocate the AC?
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 02-02-2016, 07:32 AM   #44
E46XITurboJoe
Function and Form. I would like this to be a mild VIP build so A/C is a must and simply I live in Florida at the moment ahah
Old 02-02-2016, 09:53 PM   #45
E46XITurboJoe
pretty stoked about how smooth everything is coming together at this point!
UPDATE
I wanted to move my A/C lines, condenser(I think its called?) and washer fluid to the ABS pocket so here we go
this is what I was thinking, obviously the lines will need to be re-bent.
from here I used a bunch of old angle and box steel to make up a quick bracket, this is another 1 of a million reasons I keep all my left over nuts and bolts from projects I have yet to buy new hardware.
here it is installed. this piece will also hold the mounting points for the washer fluid tank I am making. (material is in the mail) I am going to actually have to weld the tank aluminum nice. I have been lazy so far.
I will have to grind and repaint the bracket once I add the last box tubing for the mounting point for the washer tank, but this keeps the rust on this old metal from getting worse!
thanks again
trying to get my A/C lines made and brazed up tomorrow!
Old 02-06-2016, 07:21 AM   #46
limpiabota809
My Ride: 330 XI
I can't see the pics, I'm on the app
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 02-06-2016, 08:48 AM   #47
MichaelStar
My Ride: 325 Touring
Cant see them either on the website
MichaelStar is offline   Reply With Quote
Old 02-06-2016, 08:57 AM   #48
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
The problem is some photo hosting sites require you to be logged in to see the pics. Need a different hosting site OP.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 02-06-2016, 10:16 AM   #49
E46XITurboJoe
I noticed that when I check this thread when I am on a new computer, thanks for the heads up
Old 02-06-2016, 10:16 AM   #50
E46XITurboJoe
what site would you recommend?
Old 02-06-2016, 10:21 AM   #51
E46XITurboJoe
Update
so hard / bad news this morning.
I started unbolting the exhaust manifold for the turbo install and I had a weird feeling to check the oil cap. I unscrewed it and there was 'milkshake' so now I am stopped trying to decide if it is time to retire this car / project or if I want to try another head gasket. a had another head gasket swap on a 2.5 liter m54 that went and now this complete 3.0L swapped in appears to have gone.
options and options are greatly appreciated. my best idea right now is to install the turbo manifold and it appears that when the head gasket arrives I can pull the head and leave the intake manifold and turbo manifold on. then I just need to have a shop re-align the vanos.
ideas are appreciated.
Old 02-06-2016, 11:24 AM   #52
mikeetastic
My Ride: lots of 3
so much wasted time
mikeetastic is offline   Reply With Quote
Old 02-06-2016, 11:33 AM   #53
E46XITurboJoe
Originally Posted by mikeetastic View Post
so much wasted time
ya I feel like this always happens, I checked all the fluids right before I started my A/C line project now I am half way done and its all for not. I really want to repair the motor / swap in a new one but I just don't think its feasible
Old 02-06-2016, 12:06 PM   #54
18rabbit
My Ride: '02 330it
So with every 3 series that I've had, there has been a 'milkshake' found under my gas cap during winter months, and it has not been from bad HG's but from less than stellar CC breathing systems and short drive times. I know you're in FL but I would check for oil in coolant, drain oil and look for coolant or water, then do a compression test before anything else.
18rabbit is offline   Reply With Quote
Old 02-06-2016, 12:08 PM   #55
18rabbit
My Ride: '02 330it
Also, if your going FI, you'll want a better HG anyways. I've done 2 HG repairs on the M5X engines I think they are pretty cake, not to mention you get to repair all those little vac lines.
Old 02-06-2016, 04:00 PM   #56
MichaelStar
I doubt it is headgasket. Check post #2
http://forum.e46fanatics.com/showthr...=#post16878342
Old 02-06-2016, 04:44 PM   #57
E46XITurboJoe
I will when the rain stops, however its been drinking coolant as well....
Old 02-06-2016, 04:46 PM   #58
E46XITurboJoe
thank you! I will check that as well. the first motor in this car had bad compression/ blown head gasket and came that way, not sure how how the dude drove the car but everyone makes it sound like he must have had to drive the wheels off it to get it that way.
after trying a head and HG swap- which also blew, I went with a new motor.
Old 02-06-2016, 04:47 PM   #59
E46XITurboJoe
I am mainly afraid that if it is a bad head gasket it'll be the same thing that happened on the old motor, replace the HG and put a new head on and then have it go 600 miles later.
I do really want to keep this car! I love the lines
Old 02-13-2016, 07:29 PM   #60
E46XITurboJoe
**update***
sorry for the wild cliff hanger- but here is an update. I decided to keep building the car, a lot of the reason is the instant support on here, I am going install and sort out the whole turbo install. and then diagnosis the engine before I drive it / tune it. my thinking is this turbo manifold doesn't need to be removed from the engine to get the head off the car. so its a lot less time if the head does indeed need to come off.
so here are the photo updates. I am now trying Photobucket as it appears Imgur sucks..
I started the washer fluid holder. my welds are getting a lot better - technique and cleaning methods are improving, but I apologize for the sloppy welds.
this metal is thicker than i wanted, but at least it'll stop stray bullets. heres all the lay out marks pre cutting.
mocking up for welding
mostly done
needs to be cleaned up a lot. but its functional
it has since been cut down a little bit and still needs a few more welds and a tab installed
325xi, diy, turbo, wagon, write up
