Old 12-22-2015, 04:07 PM   #1
Qwest
My Ride: 2004 330xi
Not Quite Sure What's Wrong
My car has been sitting for a little while as I'm a college student and didn't want to pay for the full coverage on my car (2004 330xi 6 speed). I did however start and run it monthly for the past year and a half. Recently started having some problems. After jumping the car (it's cold here and not running kills the battery, its a brand new battery by the way, couple months old) I'll pull the cables off and let the car run, rev it a couple times, and then the tachometer stops moving, my radio turns off, the A/C and heat controls turn off, the premium sound light by the shifter starts flashing, and alas, my car dies. I've tried jumping it again thinking the battery just wasn't charging quickly enough to keep up, but even after trying another jump it won't start. Also as soon as it does start (when it does) the speakers start popping and crackling. Maybe it's a bad ground? Has fresh gas and my dad dumped some heet in it while I was in school. Not sure what could be wrong.
Qwest is offline   Reply With Quote
Old 12-22-2015, 05:41 PM   #2
My325XI
My Ride: 03 325XI Sprt Prem
Maybe an alternator, or voltage regulator issue if all the other stuff shuts off after it's running, plus battery may need a full charge.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 12-22-2015, 08:22 PM   #3
jmo69
My Ride: 03 325xi 98 328is
Try a search for OBC hidden menu. It will give you the alternator voltage output plus many other things. I've had failed alternators and never had any of your symptoms. Just no starts and maybe a battery light.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 12-22-2015, 08:27 PM   #4
zander271
My Ride: 6spd ZHP/5sp XI
OP sounds like the alternator, you need to check the voltage like jmo stated. If you see less then 13.5-14, I would just replace the alternator. It could be the voltage regulator but most of the time it's just the alternator. It's a really easy job. I've done twice and had to remove it for other jobs done on both my e46. If it's your first time budge 2 hours if you are quick 30 minutes. Also have a crow bar ready.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 12-22-2015, 08:38 PM   #5
jmo69
I can see 30 minutes on a manual like his, but automatics like mine will take longer. I can get mine out in about 20 but I'm on my fourth.
Hers His
Old 12-22-2015, 09:36 PM   #6
Carina2002
My Ride: 2002 330xi
I also wouldn't recommend disconnecting your battery cables while it runs. That allows the alternator to charge it. And what you describe sounds like an alternator issue. Check the voltage and replace of it is under spec.
[/SIGPIC]
Carina, WIP
2002 330xi
Sport Package, Auto
Carina2002 is offline   Reply With Quote
Old 12-23-2015, 08:06 PM   #7
Qwest
My Ride: 2004 330xi
I thought maybe it was a bad ground at first because of the speaker noise (I have the harmon kardon system so maybe it's the amp not being powered properly) on the plus side I got to see my newly installed angel eyes light up before it died.
Old 12-24-2015, 11:29 AM   #8
Kubica
My Ride: 2003 325xi
Remove angel eyes. Problem solved.
Old 12-24-2015, 12:06 PM   #9
Qwest
My Ride: 2004 330xi
Too bad it was happening before I installed them.
Old 12-24-2015, 06:58 PM   #10
jmo69
I think he means the jumper cables. I'd charge the battery and have it tested, if it's good put it back in and start it then check the voltage at the battery while it's idling, should be close to 14v. Had a low battery on mine yesterday, charged it and when it started I had 14+ at the battery. Going to charge it again on Friday at have it tested on Saturday just to make sure, it's gonna be cold next week.
Hers His
Old 01-01-2016, 10:47 PM   #11
jmo69
Battery tested good, the guy held the load longer than usual and it passed, Rayovac, purchased in July of 2012.
Hers His
330xi, electrical, engine, problems
