Just Another M54 Turbo Build. By the People, for the People - Page 22 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-01-2017, 12:43 AM   #421
Pole position
My Ride: E46 330ci
Originally Posted by Tonygindey View Post
What did you do about the secondary air pump?
Deleted, not needed when you delete cars anyway
Shut up and drive
Pole position is online now   Reply With Quote
Old 01-01-2017, 01:32 AM   #422
Tonygindey
My Ride: 325ci
[QUOTE=Pole position;17148768]Deleted, not needed when you delete cars anyway
did you do anything about the cel for it?
How did you delete it? Did you make a block off plate for it or is there a kit I can buy?
Sent from my iPhone
Tonygindey is offline   Reply With Quote
Old 01-01-2017, 03:17 AM   #423
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
[QUOTE=Tonygindey;17148772]
Sent from my iPhone
Some people just leave the valve bolted to cylinder head on, and pull everything else off.
A little piece of 3/8" aluminum plate cut to size with 2 holes drilled through it is all that's really required otherwise.
I ordered a block-off plate from the Euro model I think....was silly expensive...should have just used a piece of aluminum.
Old 01-02-2017, 03:08 AM   #424
Davew
My Ride: 2004 330ci Msport
Euro block off, on the spare head.
Davew is offline   Reply With Quote
Old 01-02-2017, 04:48 PM   #425
Pole position
My Ride: E46 330ci
I have the code blocked using info from the ms43 tuning thread in the dme section of the forum
Shut up and drive
Old 01-02-2017, 11:55 PM   #426
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Yup.
I ordered that from BMW, then also found one on a cylinder head I bought from Sweden.
Old 01-04-2017, 03:52 PM   #427
Pole position
My Ride: E46 330ci
So I just got this oil cooler in. Do you think it's large enough to be effective on a track day? Could always put a larger one in the fender well with a fan
Also I finally got the rear rotors back from the machine shop. I needed the inside lip meant for the ebrake shoes removed because the interfered with the calipers I got. They looked the same as stock but aren't quite. Hopefully will have them welded in soon, had some issues making brackets. Now have some steel nubs sent to me that should help get a strong mount going from SRS.
Shut up and drive
Old 01-04-2017, 04:27 PM   #428
cwarel
My Ride: 330ci coupe
I think this oil cooler is big its twice thicker the one i got. But if i were you i would place it in the fender so the radiator gets all the air flow so ur engine doesnt overheat where oil can be cooled with a fan in the fender area
Or i see u got this hood with fins in it ,you could place oil cooler near it i guess
cwarel is offline   Reply With Quote
Old 01-04-2017, 11:09 PM   #429
Pole position
My Ride: E46 330ci
Yeah I'm going to pull off the front fender tomorrow to see how much area I have to work with. The car will have a splitter soon that I'm making, so that should help with directing air toward the CSF upgraded rad a bit more directly. Once drove a rx7 race car that overheated without the splitter.
Luckily I have a while to exchange oil coolers from summit.
I'm not sure the extent of cooling these engines need?
Shut up and drive
Old 01-05-2017, 12:10 PM   #430
Pole position
My Ride: E46 330ci
Some very big news coming soon! Let's just say the car is going to have a biggggg booty now.....
Shut up and drive
Old 01-06-2017, 10:37 AM   #431
ernestas
My Ride: BMW e46
Hello every one, hawe one question, i going to do e46 330ci turbo, 600cc injectors turbo garret wanna use it on 0.7 bar. going to adjust standart ecu, compresion rate is 10.5 fuel e98 fullfuly remanufactured engine. arp head studs all parts oem new. soquestion will it workfine on 300-350 hp ? or i just wasting my and yours time ? thanx for answer
ernestas is offline   Reply With Quote
Old 01-06-2017, 10:48 AM   #432
Pole position
My Ride: E46 330ci
Maybe, that's part of the adventure haha
Shut up and drive
Old 01-06-2017, 10:50 AM   #433
ernestas
My Ride: BMW e46
but its possible ? iworry about engine knock on e98 or e95 because some pps told me that compresion rate is to high... 10.5 it should be 8 or 9. how you think ?
Old 01-06-2017, 10:54 AM   #434
Pole position
My Ride: E46 330ci
Yeah I recommend e85 or above
Shut up and drive
Old 01-06-2017, 10:56 AM   #435
ernestas
My Ride: BMW e46
But i wanna use e95 thats why asking
Old 01-09-2017, 08:43 PM   #436
Pole position
My Ride: E46 330ci
Getting down to some grunt work I need to get out of the way. Fixing exhaust, found the meyle hd diff bushings busted within 5k miles of turbo power while installing finned diff cover, rear sway drop-link seized, also rear driveshaft cv joint rubber and gasket in questionable condition. At least finding them now, and not while at an event
Shut up and drive
Old 01-11-2017, 08:47 PM   #437
randomdude
My Ride: ZHP, 135, X1
Are you going to replace the diff bushings with rubber or poly?
randomdude is offline   Reply With Quote
Old 01-12-2017, 12:11 PM   #438
Pole position
My Ride: E46 330ci
Changing them out with 88A poly ECS Tuning brand diff bushings. I am also installing poly rtabs while I have Mflara's tool rental. I was running z4m bushings with limiters. Waiting on the parts right now, ship date got pushed back, hopefully done by end of weekend
Shut up and drive
Old 01-14-2017, 01:45 PM   #439
Pole position
My Ride: E46 330ci
Got all the diff bushings in. While throwing in the poly rtabs I welded the seam on the mount. Not sure if it needed it but didn't think it could hurt. Still learning to weld so don't hate on my welds too much haha
Shut up and drive
Old 01-15-2017, 09:38 AM   #440
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
That stuff isn't always easy to weld on, as it is not always "virgin" steel. I've seen professional welders struggle with contamination, with perfect prep and technique. I don't think what you did will hurt the parts....it's nice to see you "doing stuff"! Most people are stuck in an armchair....
