Old 04-07-2016, 02:31 PM   #1
Andrewoio
My Ride: E46 BMW 323i
Feeling a lot of heat from the engine
Hey guys so the last few days I've noticed while driving that there's a lot of heat coming from where my pedals are. A lot more than I've ever felt before. I noticed it when I was driving on the freeway. The only light on my dash is the windshield washer light, and everything seems normal. Oil temp has never gone above the center.
It's just starting to bother me seeing that ive never felt so much heat coming through until just recently.
Any ideas?
Andrewoio is offline   Reply With Quote
Old 04-07-2016, 03:03 PM   #2
My Ride: Lexus
probably all in your head
Old 04-07-2016, 03:06 PM   #3
zander271
My Ride: 6spd ZHP/5sp XI
you don't have the heat on do you OP?
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 04-07-2016, 03:33 PM   #4
cvx5832
My Ride: 325Ci, 325Cic, C300
Any ideas?
Use the AC foot vents and it will go away.
cvx5832 is offline   Reply With Quote
Old 04-07-2016, 04:38 PM   #5
Yewzer B Lewzer
My Ride: 2003 325i
Your 323i has an oil temp gauge?
Did you buy the car over the winter? I see you have been a member since November. It's been unseasonably warm recently in issaquah.
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 04-07-2016, 04:46 PM   #6
Andrewoio
You know that is a possibility
No I usually drive with heat/AC off and windows cracked
I'll give this a try, I never do have the foot vents on. Thanks!
Yeah it has an oil temp gauge and it's always been normal, never even a little high. I bought my 323 in October and I did move down to Fairfield, CA in December. It could be the outside temp messing with me, but I usually notice it at night time which is why I found it weird.
Old 04-07-2016, 04:53 PM   #7
joegr
My Ride: 2002 325i
Aftermarket then?
How about the engine temp gauge. What is is showing?
joegr is offline   Reply With Quote
Old 04-07-2016, 05:07 PM   #8
Andrewoio
Originally Posted by joegr View Post
Aftermarket then?
Actually, my mistake I don't have an oil temp gauge I was thinking of the engine temp gauge. So the engine coolant gauge is always normal
323i
