///M3 Forum
Old 04-14-2016, 06:52 AM   #1
mattman928
My Ride: e46 M3
Torque Values Needed
I am slogging through replacing the bushings on my differential (e46 M3 2002) but cant find the torque values for....
- The Bolts that hold the differential into the subframe
- The bolts that hold the back cover onto the differential
- The bolt for attaching the rear axle (output shaft) to the differential
Thanks folks!
- Matt
mattman928 is offline   Reply With Quote
Old 04-14-2016, 07:20 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
first result on google has some of what you're looking for
http://www.m3forum.net/m3forum/showthread.php?t=546907
Old 04-15-2016, 01:50 PM   #3
E46 WOT
My Ride: 2004 M3 SMG
Just in case you hadn't seen it I have a DIY for that job http://forum.e46fanatics.com/showthread.php?t=1101104 no torque values per say but in case you needed any visuals or tips.
2004.5 M3 SMG
CF CSL Trunk, CSL replica bumper, 18x9.5 BW Arc-8 w/ 245/265 R-S3s, PFC 08 pads, SS brake lines, Prospeed 683 Brake fluid, ISC N1 Coilovers, Powerflex poly RTABs, sways, and diff bushings, solid FCABs, BW performance motormounts, Rogue transmounts, BSW I-Pod Dock, Rookie BMWCCA Club Race license, 2:08.935 VIR Full Course, BW intake boot + K&N drop in filter. Borla catback exhaust.
E46 WOT is offline   Reply With Quote
differential, torque
