Old 04-22-2016, 05:04 PM   #1
RSV
My Ride: 2001 330ci
With a new battery does your car have to be re programmed?
I just got a new battery on my 01' 330ci and the shop is saying they had to do a re program to let the car know that there is a new battery so the alternater etc works properly...
Is this true because i have had batteries installed before where this did not have to be done.
Anyone??
Thx
RSV is offline   Reply With Quote
Old 04-22-2016, 05:07 PM   #2
mpvue
My Ride: '04 325xi stick
no reprogramming necessary.
2004 325xi deleted DMF, SAC and CDV
de-engineering the over-engineered since 2014
mpvue is offline   Reply With Quote
Old 04-22-2016, 05:07 PM   #3
Synrgy
My Ride: 2000 323i
That only applies to the e90 (2006+ 3 series) our cars are old and don't need to have that kind of programming.
Synrgy is offline   Reply With Quote
Old 04-22-2016, 05:54 PM   #4
WDE46
My Ride: 2004 330Ci OBM
It's false.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-22-2016, 07:09 PM   #5
RSV
My Ride: 2001 330ci
Thanks guys...
Old 04-22-2016, 07:18 PM   #6
zander271
My Ride: 6spd ZHP/5sp XI
No
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 04-22-2016, 08:30 PM   #7
jfoj
My Ride: 330CiC, M5, X5
The easiest answer is only on models with some form of iDrive is the battery programming/registration required.
Old 04-24-2016, 02:24 PM   #8
2000E46VER
My Ride: 323ci convertible
I changed the battery on my 00 323ci a few years back
and didn't have to program anything.
2000E46VER is offline   Reply With Quote
Old 04-24-2016, 03:39 PM   #9
RSV
My Ride: 2001 330ci
Thanks for responses.. I got it sorted out and reprogramming charge dismissed...
I a so glad for this forum
RSV
Old 04-24-2016, 07:55 PM   #10
jmo69
My Ride: 03 325xi 98 328is
RSV
Who "programmed" it a judge? LOL
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
battery, help me, questions
