Old 05-03-2016, 12:29 AM   #1
MV330xi
My Ride: 330xi
Occasional P1345 after warm and under load, clears after restart
Hi - 2002 330xi with 99k miles. Occasionally when engine is warm and running under load (going up a moderate hill on hwy), the car suddenly runs very rough and throws the CEL and a P1345 code (Misfire Cylinder 2 with Fuel Cut-off). When I shut off the engine and restart, the car runs fine and the CEL shuts off (with the P1345 show as pending when pulled with code reader). This is the third time it has happened over a span of a few months, but not sure which cylinder it was last time b/c didn't pull the code. Runs fine between occurrences. Any ideas?
Spark plugs were changed 1k miles ago with NGK Laser Platinums (at 25k from last change) and didn't fix the issue - all plugs looked fine, but cyl 6 had a small amount of oil on threads. All coils+boots were replaced with OEM Brembi at 93k miles. All 4 O2 sensors were replaced at 98k. Replace fuel pump with OEM and fuel filter at 80k. Replaced DISA valve, lower intake boot, vanos line and PCV system at 81k, if it matters.
Thank you for any thoughts...
Last edited by MV330xi; 05-03-2016 at 12:47 AM. Reason: (added fuel pump+filter replacement detail)
MV330xi is offline   Reply With Quote
Old 05-03-2016, 12:39 AM   #2
swordsman11868
My Ride: 2003 325i
1. Fuel pump/filter
2. Maybe a vacuum leak.
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 05-03-2016, 04:29 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Need data, Freeze Frame and Fuel Trim info
Load related misfires are not usually vacuum leak related and I see the fuel pump has been replaced.
I would be inspecting the DISA and cylinder #2 worries me a bit due to some DME related problem.
But would like to see some data before we go any further.
Old 05-04-2016, 12:29 AM   #4
MV330xi
My Ride: 330xi
Thanks for the initial thoughts. I tried to pull the freeze data, but there wasn't any. Although the CIL turned on when it initially faulted, when I restarted the light went out and when I pulled the codes it says it was 'pending' and there wasn't any freeze frame and fuel trim data. The next time it happens, I'll try to pull the data before I restart and post what I find.
Old 05-04-2016, 08:06 AM   #5
markusmarkus
My Ride: 2001 330Ci
Done load OBDFusion and buy the proper interface from Amazon.
330xi, misfire, p1345, warm
