Old 06-06-2016, 10:00 AM   #1
beancounter88
My Ride: 325xi
Ignition Coil & Spark Plug
I have a 2002 325xi. Check Engine light came on Saturday and car started running roughly. Last time it happened, I took it into an indie shop and they replaced ignition coils 1 & 3.
Decided to try fixing it myself - so I took it to AutoZone, and they checked the check engine light, to find out that the problem was ignition coil 4 and spark plug. After purchasing the parts then and there and replacing them myself (with the help of youtube), I drove it around a bit and it was still running roughly as if I hadn't fixed anything. Loss of RPM's and power.
Is it possible that I have to replace more spark plugs? Could the loss of #4 caused others to go as well? How do I test it out at home?
I will mention that the spark plug I changed was WAY gone - even the guy at Autozone commented on how bad it looked. Maybe other plugs are in just as bad of shape.
beancounter88 is offline   Reply With Quote
Old 06-06-2016, 01:53 PM   #2
Glen-B
My Ride: 330CI Sport Auto
I think it's a good idea to check the other plugs. You might need to reset the error before it starts running normally. Did AutoZone reset the code?
Glen-B is offline   Reply With Quote
Old 06-06-2016, 02:18 PM   #3
mr ilia
My Ride: 2004 BMW 325i 5spd
You will need to reset the code and run the car again to see if it comes up again, then you do a new scan.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 06-07-2016, 07:47 AM   #4
markusmarkus
My Ride: 2001 330Ci
Post the codes.
325xi, ignition coil, spark plug
