Sponsored by The Tire Rack
Old 06-14-2016, 09:26 PM   #1
Andrewoio
My Ride: E46 BMW 323i
Will 18x8.5 wheels fit in a 3 series?
Im looking at some Beyern Spartan wheels. They're 18x8.5 with a 15 offset and a tire size of 265/35. Would they fit a 2000 323i? At least with stretched tires maybe?
Andrewoio is offline   Reply With Quote
Old 06-14-2016, 09:50 PM   #2
My325XI
My Ride: 03 325XI Sprt Prem
I'm no tire expert, but from what I know... A 265 tire is extremely wide for an 8.5 rim. 225-245 would be more the norm. The offset of 15 maybe too aggressive. I know my stock rims are in the 40's.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 06-14-2016, 09:53 PM   #3
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
Probably not -- offset's too aggressive. Figure you're looking at needing +1 inch inner (about 24mm) clearance, which might mean the rim's hitting hitting the strut and/or the inner wheel guard, and almost +1.5 inches outer (36mm) clearance (I think that may be more doable).
They do make the Spartans with ET 30 and 40, however...
Sicily1918 is offline   Reply With Quote
Old 06-14-2016, 10:49 PM   #4
randomdude
My Ride: ZHP, 135, X1
I'm running 18X8 in the front & 18X9 in the back, ET 35 on all. The backs rub over bigger bumps and aggressive turns even with the fenders rolled. That's with 255/35 Hankooks
randomdude is offline   Reply With Quote
Old 06-14-2016, 11:13 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
that offset is pretty ridiculous. the rim width is average.
Old 06-14-2016, 11:18 PM   #6
kakashi_sensi
My Ride: 01 e46 330i 6spd
Maybe, if you get 205/40 tires. I remember DTMDan ran something like that with his ACS type 2.
LEVELONE // Euro.Techniks // OEM BMW Performance Auto -> 6 Speed Complete
kakashi_sensi is offline   Reply With Quote
Old 06-14-2016, 11:20 PM   #7
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
I'm running APEX Racing EC-7's, 18" x 9.5" x ET35 in the back with Michelin Pilot AS in the rear 255/30/18. No rubbing and no rolled fenders.
/// MODS
Old 06-15-2016, 01:01 AM   #8
zander271
My Ride: 6spd ZHP/5sp XI
Lucky coupes
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 06-15-2016, 01:25 AM   #9
cottoncandyek
My Ride: E46 vert
If you get 215/40/18 they will work. Im running that size on 18x8 +13 and they fit perfectly with no camber work or rolled fenders on stock msport suspension. Anything larger will not work. No way 265/35/18 will fit without camber or body mods
cottoncandyek is offline   Reply With Quote
Old 06-15-2016, 11:32 AM   #10
Andrewoio
I've been looking through the site and couldn't see any. I only see Spartans with 15 and 25. Would you mind sharing a link?
Old 06-15-2016, 11:35 AM   #11
Andrewoio
There's no way 9.5s could fit my sedan unfortunately
Old 06-15-2016, 11:48 AM   #12
Sicily1918
Sicily1918's Avatar
It was on the Beyern website.
Where were you looking at the rims?
Old 06-15-2016, 01:03 PM   #13
matt270avian
Banned User
My Ride: 2002 325XI
I'm running 18x8 +42mm with 235/40/18s all around on Eibach springs and SP drop hats. No rubbing at all, and I'm going to try and squeeze something wider under there. 265/30/18 will fit an 8.5" wheel, but the sidewalls may bulge a little, 255 would be more appropriate. A lot of people around here like to run 205/15/25 etc... on wider wheels for stance and tire stretch so finding info on fitment can be a bit tricky. Yes you get an extra 10mm of contact patch with the 265s, but the sidewall deflection could negate that extra grip.
matt270avian is offline   Reply With Quote
Old 06-15-2016, 04:25 PM   #14
Andrewoio
Off the Beyern site as well haha. I was looking at the e39 5 series section because the only ones they offer for e46 are 17s and I want 18s hehe
Old 06-15-2016, 04:28 PM   #15
Andrewoio
I'm sitting on eibachs too and yeah I assumed they'd fit with the right tire stretch but I need a way around that offset :p
Old 06-15-2016, 04:28 PM   #16
Sicily1918
Sicily1918's Avatar
Which is lame, since the 18's they do have are perfect for E46s; 5x120 and with the proper center bore (72. crap... .26? -- whatever)
Old 06-15-2016, 08:25 PM   #17
Andrewoio
Yup I know man. Struggles lol
323i, beyern, wheels
