Old 08-31-2016, 06:49 PM   #1
iowna330xi
My Ride: is not yet fast.
Upcoming Chassis Swap
As the title says, I have an upcoming chassis swap which involves an auto to manual swap. They are both '99 323's but the one where everything is going into is from California with 100k less miles!
I just wanna get a couple things clear in regards to the coding. Can I use ncs to remove s205a in the SA and recode the car? I can swap over my manual cluster, but I am more interested in how I am going to work with the dme. Can I reflash that with winkfp? Or should I put it into bootmode and flash a 512kb file? Thanks.
iowna330xi is offline   Reply With Quote
Old 08-31-2016, 06:53 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
you don't need to swap your cluster.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 09-01-2016, 05:25 AM   #3
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
I doubt you need to flash the DME. Look up the part numbers for MT and AT and see if they're the same.
http://bmwfans.info/parts-catalog/E4..._control_unit/
///Mmmmmm...
Old 09-01-2016, 07:18 AM   #4
WDE46
He only has the program the manual option. No flashing.
Old 09-01-2016, 02:22 PM   #5
iowna330xi
Thanks for the help. So what software would I use to program the manual option. The only software I dont have is SSS and GT1
Old 09-01-2016, 02:31 PM   #6
mikeetastic
My Ride: lots of 3
removing $205 via ncs is for newer model cars with VO, older model used different type of coding.. see below
http://forum.e46fanatics.com/showpos...&postcount=322
mikeetastic is offline   Reply With Quote
Old 09-01-2016, 02:36 PM   #7
mikeetastic
My Ride: lots of 3
and to add you dont have to swap the cluster nor dme, just code them. its actually easy and the harder part is the swap lol. coding only takes a few minutes..
Old 09-01-2016, 04:25 PM   #8
iowna330xi
Thank you Mikeetastic. That should come in handy when the swap comes around.
Old 09-01-2016, 05:00 PM   #9
BaliDawg
NCS Expert. It's part of the BMW Standard Tools, which also includes INPA, WinKFP, Tools32, etc.
See this thread.
///Mmmmmm...
dme, manual, swap
