Old 09-23-2016, 09:22 AM   #1
dion9876
My Ride: 2000 e46 323ci 5sp
Complete a/c heater delete?
Does anyone have a detailed diy on how to delete the entire a/c and heating system? (For track use)
Thanks.
dion9876 is offline   Reply With Quote
Old 10-07-2016, 11:08 AM   #2
BigBill
My Ride: 01 330ci
Sledgehammer
BigBill is offline   Reply With Quote
Old 10-07-2016, 01:37 PM   #3
dion9876
Thanks, but it's out and binned already now haha, I just wanted half an idea of what was happening but it's pretty straight forward
Old 10-23-2016, 09:48 PM   #4
Phoenix1911
My Ride: 2002 M3
I wouldn't mind hearing about how you did it, any gotchas, etc. Will it throw any codes?
thanks!
Phoenix1911 is offline   Reply With Quote
Old 10-23-2016, 09:53 PM   #5
dion9876
thanks!
Well I already had the dash and everything else stripped out which made it easy to follow all the lines etc but I checked up on real oem to get an idea of where everything connected to the system. I got an a/c guy to come out and de-gas the a/c and then I pulled the belts and started undoing everything associated with it, it was quite simple now that I've actually done it, car will hopefully be started today so I'll let you know it throws codes etc
Old 10-23-2016, 11:23 PM   #6
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Did you disconnect the heater hoses and heater pipe that connect to the engine under the intake?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 10-23-2016, 11:30 PM   #7
dion9876
Yeah I done the heater side first while I was waiting to get a A/C guy out, I flushed the coolant and cut the hose coming from the back of the block with just enough hose left to put a plug in it with a hose clamp and I done the same for the hose running into the bottom of the expansion tank.
Old 10-25-2016, 01:11 PM   #8
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Don't remove the blower fan....
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-25-2016, 05:22 PM   #9
dion9876
Rob43
The blower that sits inside the dash?
Old 10-25-2016, 07:17 PM   #10
SK330ci
My Ride: 02 330ci w/ 3 Pedals
how many blowers do you have?
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 10-25-2016, 07:47 PM   #11
dion9876
So what's so bad about removing blower?
Old 10-26-2016, 01:19 PM   #12
Rob43
Rob43's Avatar
Why do you think I'm giving YOU this advice ??
Rob43
Old 10-26-2016, 02:42 PM   #13
BKMrSteel
My Ride: 99 328i
Are you leaving the dash out? It's really nice to have a simple blower for air on a hot track day I bet. Full helmet, and other gear depending on class.
Cheaper then a cool shirt.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 10-26-2016, 03:20 PM   #14
dion9876
Ah I see haha
Nah I'm not as worried about the heat, aslong as I have good ventilation! It's also a drift project so it won't see any street driving at all and on the track it will be in short intervals anyway. Worst case scenario I'll buy a mini fan and mount it somewhere
And nah BKMrsteel I'm sticking with the dash and also the front door cards haha, I'm trying to keep the interior as clean as possible even though she's gutted
Btw just an update: I managed to finish off my wiring so I could finally start the car back up! Everything is a-ok and no codes were thrown whatso ever!
Old 10-26-2016, 04:05 PM   #15
Rob43
Rob43's Avatar
Ah I see haha
Nope, that's not it. That's why I wanted YOU to take a stab at this....
Rob43
Old 10-26-2016, 04:08 PM   #16
dion9876
I'm stumped then!
the only thing I can think of is it relating to the fans in the front maybe?
Old 10-30-2016, 07:08 PM   #17
325ragtop
My Ride: needs more HP
So Rob... I know exactly why your saying don't remove the blower fan, but on the E46 it comes out as one big housing with the heater core, evaporator and flaps, etc, and it's NOT light. I'd have to take a look and see if there is a practical way to remove and remount it, or gut & cut the housing... but may not be worth the hassle. Considering making weight is a factor for some, defroster strips might be easier.... Or just use Rain-X Anti-Fog?
325ragtop is offline   Reply With Quote
Old 10-30-2016, 07:41 PM   #18
Rob43
Rob43's Avatar
Bingo Bingo, winner winner chicken dinner !
Having the ability to defrost the front windshield is paramount in certain situations. I can't & won't speak to all the continents of our world, but here in the USA there are many weather situations where a working widow defroster comes in very handy at removing condensation. For me it's a must have item.
Rob43
Old 10-30-2016, 09:15 PM   #19
dion9876
Ah I see haha, yeah that came across my mind but I'll just keep the windows down when I chuck it on the trailer, it's basically hot all year round in aus so I'm not really worried at all.
If it becomes a problem I can address it once it happens
