Old 10-16-2016, 12:56 AM   #1
bluebull107
My Ride: 325ci
[HELP] A/C Problems
So I just bought a 2004 325ci and it has a bunch of weird quirks that I am sorting out and fixing (mostly by myself). The previous owner of the car knew barely anything about it but I can tell that it was not taken care of very well mainly due to the grindings on the rims and the cut springs lowering the car. But one problem I have no clue about is that the A/C only works when I am driving?
If I am just starting the car or stopped in traffic, it will only blow hot air. Has anyone had any experience with this?
bluebull107 is offline   Reply With Quote
Old 10-16-2016, 01:35 AM   #2
noob1
My Ride: 325i
check the electric fan (number plate side of the radiator) is running. if not see if you can get it to go - it may be seized and need some help to free up, not getting power etc...
noob1 is offline   Reply With Quote
Old 10-16-2016, 08:23 AM   #3
markusmarkus
My Ride: 2001 330Ci
Is the transmission a manual or automatic?
Old 10-16-2016, 12:48 PM   #4
bluebull107
My Ride: 325ci
Its a manual transmission
Old 10-16-2016, 01:26 PM   #5
bluebull107
My Ride: 325ci
Theres some shotty wiring done to the fan motor. Its hard wired to a switch in the glove box that I have to manually turn on when I start the car so it will cool the engine. Is that the same fan?
Old 10-17-2016, 02:25 AM   #6
noob1
My Ride: 325i
sorry I've put you wrong - I assumed you had an auto. but that switch setup sounds dodgy. where I was going with it was the fan (on an auto at least) blows air through the radiators (both air con and engine) which will help give you a/c while you're not moving. if the fan isn't going, that will explain your lack of a/c when not moving. it may be worth checking if the fan is running anyway and sorting it if not.
325ci, a/c, bmw
