Old 10-31-2016, 02:33 PM   #1
Nolan_R
My Ride: 2005 TiAg 330i ZHP
Had vacuum leak fixed now white smoke comes from exhaust.
Hey everyone, I took my car to a shop and paid $85 for them to fix a vacuum leak. I picked the car up and the SES light is gone. They said it was a hose under the engine so I assume it was some CCV hose. After I drove it for a bit, white smoke started coming out of the exhaust when I took off from idle. It smells burnt. I read that I should just go on a 20 minute drive to let everything burn up but I just want to make sure that it sounds normal.
Nolan_R is offline   Reply With Quote
Old 10-31-2016, 02:49 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Find out what hose was replaced.
The smoke may be coincidental or it may be due to the repair.
Chances are a CCV hoses was bad, probably the CCV lower oil return line that connects to the dipstick. If the CCV is bad, it may now be pulling a lot of oil vapor or oil into the intake.
The CCV and hoses probably should have been replaced on the engine would be my guess. Not just a single hose replacement.
ccv, exhast, vaccum leak, white smoke
