Mechanical Over-Rev - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-08-2016, 07:25 PM   #21
eforer
My Ride: 03 325Ci
Alright I did the compression test today, found some time from work so I didn't have to have a shop do it.
I know the spec is 142-156psi for e46
Mine showed between 175-185 for cylinders 1 thru 5, possibly because 325 has compression rate of 10.5-1 as opposed to 330s being 10.25-1
I did every cylinder twice and fuel pump fuse was removed, cranked engine 5 times
Cylinder 6 which is where I have my misfire read 70psi.
Went in with a boroscope and saw a slight shiny bit on the the top of the Piston near the relief area for the valves, on the exhaust side.
Couldn't clearly make out a bent exhaust valve on the camera but it doesn't have to be off by much to cause a problem.
I removed my CCV today which only took about 3 hours wasn't as horrible as every makes it out to be, just cut the old hoses instead of trying to unclip them from the CCV unit.
Inspected inside the CCV, no gunky yellow buildup it just probably failed due to the high pressure of engine running over 7500rpm.
I'll be attempting to remove the cylinder head and inspecting it, I also found a local cyldiner head for e46 for $500, 2000km on it. Are these interchangeable between 323/325/328/330 or are they different for each engine size
eforer is offline   Reply With Quote
Old 11-08-2016, 07:38 PM   #22
Rob43
My Ride: 03 331Ci 5spd R1200R
Considering what you just posted, I have no Idea why you're bothering with a different head.
Go to your local dealer (or online) & purchase an exhaust valve and valve seal, then install & lap in.
Done.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-08-2016, 08:51 PM   #23
eforer
My Ride: 03 325Ci
Done.
Rob43
It's just an option for when I get head inspected, if it's warped it would be cheaper than getting it machined
Old 11-08-2016, 09:01 PM   #24
Rob43
If it never got HOT in an overheat scenario, 99.9% says it straight....
Rob43
Old 11-09-2016, 09:09 AM   #25
Landlorder
My Ride: 330CI Sport
Yo just change the valves etc ! ! Im at 200k miles now with a money shift i did at 140k 5 years ago...!
Landlorder is offline   Reply With Quote
damage, engine, shift, valve, valve adjustment
