Old 11-18-2016, 10:26 AM   #1
Evendahl
My Ride: 330ci Supercharged
330ci Supercharger octane booster
recently bought a 330ci with a supercharger that is mapped to run on 98 octane. the problem is that i dont have 98 available in my area, I only got 95. Can i add octane booster to add octane and prevent pre ignition ? and is there any good onctane boosters on the market that can raise the octane by 3 ?
Evendahl is offline   Reply With Quote
Old 11-18-2016, 10:30 AM   #2
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 Orient 330i/5
Octane boosters are a scam.
Have the engine retuned for lower octane.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 11-18-2016, 10:37 AM   #3
Evendahl
Im going to get it retuned, i just want a temporary solution that will reduce the chances of pre ignition.
Old 11-18-2016, 10:51 AM   #4
lingon300k
My Ride: 2005 325xi Automatic
You could probably add up to a liter of ethanol or methanol whenever you fill the tank from empty. That would probably take your 95 octane up to 98, or at least closer to 98.
lingon300k is offline   Reply With Quote
Old 11-18-2016, 12:03 PM   #5
Pole position
My Ride: E46 330ci
knock sensors, just dont drive it hard. Or add some e85 to each tank
Shut up and drive
Pole position is offline   Reply With Quote
Old 11-18-2016, 12:09 PM   #6
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
You could buy a meth injection system from AEM or Active Autowerke... but you will want to get the car tuned ASAP either way
Timeless Motor Group
Old 11-18-2016, 05:28 PM   #7
Evendahl
how much e85 per tank will I need to raise the octane from 95 to 98 ?
Old 11-18-2016, 05:42 PM   #8
chesthing
My Ride: 2002 325XI
Does Norway not have Google?
chesthing is offline   Reply With Quote
Old 11-18-2016, 06:00 PM   #9
Evendahl
nope
Old 11-18-2016, 06:19 PM   #10
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Blend a ratio of about ~25% E85 with about ~75% 95 octane, this should give you what you want.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-18-2016, 06:20 PM   #11
Evendahl
Rob43
ty
Old 11-18-2016, 06:26 PM   #12
Rob43
Rob43's Avatar
ty
Your welcome...
What I want for the E46F community is for you to post up ALL of your results & thoughts on how well you think this works for you.
Also you shouldn't need a new tune, this will work as your new "chemical" tune.
Rob43
Old 11-18-2016, 06:27 PM   #13
lingon300k
You might want to start adding some Stabil Marine, Gumout All in One, Redline Sl-1, etc, to each tank to help counteract the negative effects of the ethanol.
http://www.fuel-testers.com/list_e10_engine_damage.html
Old 11-18-2016, 06:28 PM   #14
Rob43
Rob43's Avatar
^ Good call.
Rob43
Old 11-18-2016, 06:28 PM   #15
BKMrSteel
My Ride: 99 328i
E85 is about 105 octane, although it's stoichiometric value is closer to 10.1 (opposed to 14.7). I can get my books out if you want exact numbers, but probably around 3-4 gallons. You start risking lean conditions if you use much more.
Edit: dang, Rob43 the race car driver beat me to the line, and with more information too!
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 11-18-2016, 06:35 PM   #16
Rob43
Rob43's Avatar
Certainly your contribution is also excellent.
Based on what I said plus what you said, I'd estimate roughly 97.5 octane (~93 USA) once mixed.
Rob43
Old 11-18-2016, 06:45 PM   #17
Evendahl
appreciate it
Old 11-18-2016, 06:55 PM   #18
Rob43
Rob43's Avatar
appreciate it
Again, when you get results... give back to the E46F community.
Rob43
Old 11-18-2016, 07:11 PM   #19
BKMrSteel
My Ride: 99 328i
Now I have alternative fuels on the mind, perfect for a young male on a Friday evening haha. How much Everclear do we think it would take? Might cost the same too haha
</a>
Old 11-18-2016, 07:14 PM   #20
lingon300k
That's what I want to know, more or less. I wonder how much denatured alcohol would have the desired effect, if added to the 95 octane gasoline.
330ci, octane booster, pre-ignition, supercharger
