Old 12-05-2016, 03:37 AM   #1
peteris_b
330ci - My 1st car, in love
peteris_b's Avatar
My Ride: 330Ci VERT
Advice on spark plugs needed
Hello E46 fanatics, new member here with my E46 330ci lemon.
So here I am having a difficulty to choose from spark plugs, In local shops sales people are pushing nkg plugs. But never listen to the shop staff they will always say good things about theirs stock.
So far I have considered:
Bosch super 4
Brisk dor15lgs
And something strange just came up
Vta 3d spark plug
https://m.alibaba.com/product/113896...PARK-PLUG.html
Any advice will be appreciated_a_
peteris_b is offline   Reply With Quote
Old 12-05-2016, 10:39 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
NGK BKR6EQUP, that's what comes from the factory and what the majority of us use and recommend.
Old 12-05-2016, 10:44 AM   #3
goodmanr
My Ride: 01 325i Sprt&PremPkg
NGK, the worlds best spark plug!
goodmanr is offline   Reply With Quote
Old 12-05-2016, 10:59 AM   #4
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Thank you for your reply, so in the essence the advice I stick to OEM, so the advertised benefits of performance plugs doesn't help? Like e count?
Old 12-05-2016, 11:03 AM   #5
Bigc2016
My Ride: 328i
What was the purpose of the video and timer ?
Bigc2016 is offline   Reply With Quote
Old 12-05-2016, 11:12 AM   #6
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
I believe the purpose of the clock in the video to show that footage is realtime, those plugs can only be found on alibaba
Old 12-05-2016, 12:28 PM   #7
goodmanr
A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer car engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Old 12-05-2016, 12:37 PM   #8
hitbyastick
My Ride: 2002 325i
The best reason to stay away from them
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 12-05-2016, 12:42 PM   #9
lingon300k
My Ride: 2005 325xi Automatic
Actually, to take this a step further, the cheap "hot" plugs provide the best performance. They just don't last as long.
NGK 6962 are the better plugs to buy if someone wants better performance. And it's not a big deal to replace them on this engine. http://forum.e46fanatics.com/showthread.php?t=1109150
lingon300k is offline   Reply With Quote
Old 12-05-2016, 12:50 PM   #10
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
So correct me if I am wrong:
Long lifespan - the recommended standard plugs
Performance plugs - shorter lifespan
Old 12-05-2016, 12:55 PM   #11
BKMrSteel
My Ride: 99 328i
I'm using standard NGK coppers, but unless you LIKE checking your plugs every 20k miles, get a better plug.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 12-05-2016, 01:11 PM   #12
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Thank you guys for the advice so far from everyone, the only thing what seems strange that nobody is recommending performance options. I agree what bkmrsteel said if you go for something more extra you will be changing plugs quite often
Old 12-05-2016, 01:13 PM   #13
Snowbird
My Ride: 02 325i
Copper plugs are the most efficient i.e. The cheap ones but they don't last as long as platinum or iridium tipped plugs. So in essence if your looking for the best plug possible go with a copper core ngk or equivalent but plan on changing them around 30k miles. Where iridium plugs are good to 100k at least
Snowbird is offline   Reply With Quote
Old 12-05-2016, 01:28 PM   #14
Bigc2016
My Ride: 328i
lol I guess because our computer system wont even let us get on this site.
Old 12-05-2016, 02:22 PM   #15
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Your compan block alibaba? Strange haha, still 360 degree spark plug l interesting, interesting, it?
Old 12-05-2016, 02:42 PM   #16
All2kool
My Ride: 2002 325Ci
I installed Bosch 4417's a few weeks ago and all is well. Paid $4 each for them.
All2kool is offline   Reply With Quote
Old 12-05-2016, 03:31 PM   #17
WDE46
My Ride: 2004 330Ci OBM
Spark plug marketing is mostly bullshit. Just get OEM plugs.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 12-05-2016, 03:44 PM   #18
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Let's say the vehicle has got some 143k miles on it, with most likely gunked up combustion chamber, would OEM plugs perform the same? Or is is worth t compensate with a plugs witch has larger electrode surface area?
Old 12-05-2016, 03:50 PM   #19
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP,
Why is your Bimmer a "Lemon" ?
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 12-05-2016, 04:14 PM   #20
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Originally Posted by Rob43 View Post
OP,
Rob43
Remember "Colin" from car Throttle? Almost the same situation here, haha
But to tell you the truth I love it, because it is a perfect project car to work on. So far refurbished air intake, ICV, DISA, replaced cooling fan and Valve cover gasket. Still need to replace ccv all vacuum lines, overhaul cooling system, flush the engine lots of work. But I love it
Sent from my SHIELD Tablet using E46Fanatics mobile app
330ci, advice, e46, spark plugs
