Old 12-05-2016, 03:19 PM   #21
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Search:
1) AC Delco X66P
2) BG44K
Both exceptional products for restoring performance.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 12-05-2016, 03:23 PM   #22
peteris_b
330ci - My 1st car, in love
peteris_b's Avatar
My Ride: 330Ci VERT
Originally Posted by Rob43 View Post
Search:
1) AC Delco X66P
2) BG44K
Rob43
Thank you for your advice Rob43, it looks like two good products to clean up the mistreatment by the previous owner
Sent from my SHIELD Tablet using E46Fanatics mobile app
peteris_b is offline   Reply With Quote
Old 12-05-2016, 03:31 PM   #23
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Search:
1) AC Delco X66P
2) BG44K
Rob43
Wait wait wait... Ac delco x66p apparently needs to be poured measured amount directly into cylinders and had to be driven for 20 - 30 min. Sounds like neighbours are gona be smoked hahah
Old 12-05-2016, 03:48 PM   #24
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by peteris_b View Post
Let's say the vehicle has got some 143k miles on it, with most likely gunked up combustion chamber, would OEM plugs perform the same? Or is is worth t compensate with a plugs witch has larger electrode surface area?
no. you're overthinking it. Your combustion chamber doesn't get "gunked up". It's just got a little carbon in it. Nothing more.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 12-05-2016, 03:54 PM   #25
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Yeah, I am worried about camshafts and the oily parts
Old 12-05-2016, 03:58 PM   #26
WDE46
Dude just change the oil, put in new plugs and drive your car...not sure what you're so worried about.
Old 12-05-2016, 03:59 PM   #27
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
I have rough idle and bank 1 bank 2 lean codes
Old 12-05-2016, 04:05 PM   #28
WDE46
Well that's got nothing to do with plugs and cam shafts then. You just have a vacuum leak probably. Change your intake boots and look for other broken vacuum hoses.
Old 12-05-2016, 04:10 PM   #29
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Checked thoroughly and refurbished the whole air intake all the way to the throttle body.
By the way thank you for the advice, I a very impressed an kinda really like this forum, really good advice from people who love their cars
Old 12-05-2016, 04:10 PM   #30
CylonRed
My Ride: '01 E46 330i sport
Plugs generally not going to fix lean codes (nor will cleaning the cylinders) - that is a separate issue.
The rough idle is likely caused by the lean codes and from what I have read - you have not finished the work that would effect the lean codes.
CylonRed is offline   Reply With Quote
Old 12-05-2016, 04:13 PM   #31
peteris_b
peteris_b's Avatar
My Ride: 330Ci VERT
Indeed, I am very overwhelmed of the complexity of that process to replace ccv and all the vacuum lines, cheap parts available, but scared to be honest
Old 12-05-2016, 05:14 PM   #32
das_autobahn
My Ride: 2004 330ci coupe
Advice on spark plugs needed
ngk nuff said
make sure to put a light coat of anti seize on threads.
das_autobahn is offline   Reply With Quote
Old 12-05-2016, 06:11 PM   #33
WDE46
330ci, advice, e46, spark plugs
