Ground loop noise from USB power - SOLVED! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 12-06-2016, 10:13 PM   #1
Archbid
My Ride: 2003 330cic
So I hacked together a Bluetooth device that connects to the Aux input so that I could play my iPhone over my stock nav unit. I ran a 5v USB line from the fuse box, and it worked great.
As long as I was actively playing music or a podcast.
If I stopped the playback I got horrible interference, which I suppressed using a standard ground loop suppressor, with moderate and unsatisfying results.
On a tip, I tried a DCDC isolating step down converter, and it has been life changing. Turns out the noise was from the actual usb power being noisy (I had been using a $6 simply step down converter).
The product:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I made a quicky enclosure for it on my 3d printer and plugged in the bluetooth device. No noise. None. Zero. The DC power was clean.
Might be something to try if you are using a pi-based approach or a USB powered DAC. I searched for a long time for this solution. Hopefully it helps!
Archbid is offline   Reply With Quote
Old 12-06-2016, 10:52 PM   #2
Quidzel
Past Site Sponsor
My Ride: BMW i3
It makes a lot more sense to cut the ground loop at the Bluetooth power inlet than trying to isolate the audio signal outputs galvanically or through transformers that have a non linear frequency response. Great work!
Quidzel is offline   Reply With Quote
bluetooth, ground loop, interference
