Old 12-21-2016, 01:31 PM   #1
06.325ci
My Ride: 2006 325ci
Car sounds too loud !
Hey guys so basic layout is my car sounds crazy loud inside and gets very loud at around 45mph+ . But for some reason when i steer to the left on the highway it dies down dramatically , and once steering wheel is back to center it sounds up again. Been like this since ive had it. Are there any reasons for this ? Ive heard it could be something with the exhaust but im not too sure?! Any ideas help , thanks!
06.325ci is offline   Reply With Quote
Old 12-21-2016, 01:36 PM   #2
Pro325ie46
My Ride: 2004 BMW E46 325xi
I dont think the exhaust is affected by steering in any way. Power steering pump possibly...?? What kind of sound is it...
Pro325ie46 is offline   Reply With Quote
Old 12-21-2016, 01:40 PM   #3
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 Orient 330i/5
What's the condition of your heat shields and exhaust hangers? If one is loose your exhaust could be contacting the underside of the car and creating additional noise.
Current: '02 330i/5 '06 XC90 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 12-21-2016, 01:42 PM   #4
jdstrickland
My Ride: '94 325iC & '00 323i
Nowhere near enough to go on. The skinny description of the symptom set makes me lean to the wheel bearings as a problem, or perhaps tire trouble. When you turn the steering wheel, you alter the weight and balance of the car, this makes the noise go away and return. I put this sort of thing on wheel bearings and/or tires.
Old 12-21-2016, 01:44 PM   #5
jdstrickland
I like this diagnosis. You do not tell us what the sound is, a heat shield would produce a rattling noise, the tires/bearings would make a rubbing/pulsating noise as the affected area goes around and around.
Old 12-21-2016, 01:50 PM   #6
06.325ci
My Ride: 2006 325ci
Sorry guys about the little description . Thats all i know though. Its just incredibly loud in the cab and it sounds louder at around 45 mph and on but lowers slightly around 65 mph iwill try to take a cideo later on and see if that helps
Old 12-21-2016, 02:48 PM   #7
Bigc2016
My Ride: 328i
Might want to make a video of this issue.
Bigc2016 is offline   Reply With Quote
Old 12-21-2016, 03:49 PM   #8
06.325ci
My Ride: 2006 325ci
Ill take a video later and post it around 5
Old 12-21-2016, 04:35 PM   #9
cvx5832
My Ride: 325Ci, 325Cic, C300
Your description is exactly how it was for me when one of my rear bearings went out.
cvx5832 is offline   Reply With Quote
Old 12-21-2016, 06:59 PM   #10
Poolman
My Ride: 525 BMW
Should also check your cooling fan. The fan can get loud before it goes off like a grenade and destroys a bunch of stuff under your hood.
Poolman is offline   Reply With Quote
Old 12-21-2016, 09:19 PM   #11
Bigc2016
My Ride: 328i
if its sounds like this then its one or 2 of your bearings, I think you mention that when you turn it seems to calm down. Now that I remember that is what my E36 was doing and it was my one of my rear bearings.
I replace both of them and I was good 2 go.
Old 12-22-2016, 10:24 AM   #12
ben325I
My Ride: 02 325i / 00 323i
Mine had a speed sensitive droaning sound. Thought it was the bearings. Turned out to be just the lousy Goodyears. I replaced it w/ some Michellins and all is well again. It was loud though since the tires still had a ton of thread life left. They were just badly cupped.
ben325I is offline   Reply With Quote
Old 12-22-2016, 02:49 PM   #13
jdstrickland
Smart money would be wondering why the tires had a ton of tread left, but were badly cupped. This indicates suspension issues that will soon make the new tires be cupped also.
But, yes. Road noises that change when the load on the car changes points to the tires and/or bearings.
Old 12-23-2016, 12:30 PM   #14
06.325ci
My Ride: 2006 325ci
Hey guys took a video last night and you kind of have to put it next to your ear if you have mobile. Really hopes this helps narrow it down.
Old 12-23-2016, 02:09 PM   #15
jdstrickland
I'm sticking with the wheel bearing somewhere. Having said that, the diff is an option. The center support bearing. You have said that the noise changes when you turn, this says that the load on the tires changes, which brings us back to the wheel bearings.
exhaust, loud engine, loud noise from rear end
