BMW Missfire E46 M54 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-12-2017, 02:30 AM   #21
Adam E46
My Ride: BMW 330CI 2001 e46
Well at least its a good start.
I did change the oring with an OEM part from www.oembimmerparts.com/
fuel filter was changed about 13k miles ago.
I have not changed the fuel pump, what to do to inspect it or verify if its an original part ?
I smoked tested the vehicle 3 times, no leaks from intake boot, CCV or components.
luckily tomorrow i am off, I will take another look and try to get a better evaluation.
Adam E46 is offline   Reply With Quote
Old 01-12-2017, 05:32 AM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
I am unaware if oembimmerparts offers the proper O-ring for the 325/330 engine.
If the O-ring was green it was probably not the correct O-ring.
BMW does not offer a replacement DISA O-ring for the 325/330 engines, the 323/328 engines did have a serviceable DISA O-ring.
The 323/328 O-ring is 1/8" thick, which is too thick for the 325/330 DISA. The O-ring for the 325/330 is 3/32" thick and is not a standard part as this O-ring replacement is a hack or modification.
So you might want to double check what you have or post a link for the part you purchased.
You really need to monitor the Fuel Trims as this will give you a better idea about what is going on with the engine in this car.
Old 01-28-2017, 07:28 PM   #23
J30hershey
My Ride: 03 325xi
So I've had the similar issues. Replaced DISA, valve cover gasket, inspected boots etc. Tonight I was cleaning the ICV and put it all back together and bam, idled perfectly.
Decided to take it for a drive and it was choking out when u gave it gas so I pulled back in and inspected it all again and found I didn't reconnect the small boot to the ICV, so I put it on and bam, back to idling like crap. Any suggestions?
J30hershey is offline   Reply With Quote
Old 01-28-2017, 08:23 PM   #24
jfoj
J30,
You may need to start your own thread for the problem you are having.
But in the short term, suggest you study these threads:
330ci, bmw, e46, missfire
