Sponsored by The Tire Rack
Old 12-30-2016, 10:16 AM   #1
tms95M3
My Ride: 03 M3
Just Realized My Tires Were Causing Me Grief
My summer tires are Contis ExtremeContact DW, 19". I've been suffering noises similar to brakes dragging or wheel bearings going bad. Initially, I suspected the bearings, which I replaced. I did the wiggle test, but they were fine. With that said, my e36 M3 had bad wheel bearings without any play, so I felt comfortable changing them. Noise was still there lol.
I suspected my newly acquired ST40s were dragging. Couldn't find a thing. About a month ago, I put on my winter setup. It took about a week to figure out the noise went away after I switched. To prove this, I swapped back the fronts and drove around the noise was back lol.
The sad thing is, the front tires still look perfect, deep tread and no wear. I literally put 2 new rears tires a couple of months ago, since I had a blow out. Do I buy new fronts or go broke by buying a new complete set Pilot Sports or something else?
tms95M3 is offline   Reply With Quote
Old 12-30-2016, 12:35 PM   #2
generalvp
My Ride: 05 330ci
If the tires are still within thread wear warranty, why not give it a shot? Can't go wrong with PSS though. Had a set of S04 Pole Position and though they grip like crazy, they also tramline like crazy, weighs a ton and have flat spots every morning.
generalvp is offline   Reply With Quote
Old 01-04-2017, 03:19 PM   #3
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
The Conti's are not considered a noisy tire. I would switch the front tires to the back and see if the noise changes to the rear.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 01-04-2017, 03:27 PM   #4
SK330ci
My Ride: 02 330ci w/ 3 Pedals
They're most likely cupped, go out and feel them up like they're an 18 yr old girl to see if the are. Cupped tires are noisy as hell.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
