Old 01-01-2017, 05:28 PM   #1
Jacanoryyy
My Ride: 318i
Help please
Hi all I have a e46 318i 2003 really in love with it and it's only done 62000.
However a problem has came along where when I'm driving if I take my foot off the accelerator to change gear the radio turns off and all the lights in the car kind of go dim and it will continues to do this until the engine cuts out but when the engine does cut out the lights are all bright as usual radio comes back in fine but the rev counter will stay at 1 and the EML light comes on then I turn the car off and it's like none off it ever happened for another day or 2. Any feed back or suggestions would be great! Cheers for reading!
Jacanoryyy is offline   Reply With Quote
Old 01-01-2017, 07:49 PM   #2
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Read the trouble codes of all modules with BMW Scanner 1.4.
Check battery voltage with engine off and engine on.
///Mmmmmm...
BaliDawg is online now   Reply With Quote
Old 01-01-2017, 08:22 PM   #3
jfoj
My Ride: 330CiC, M5, X5
Use the OBC to display the charging Voltage. See the Hidden OBC Menu info here - http://forum.e46fanatics.com/showthread.php?t=239619
Sounds like a charging/battery/engine to body ground problem.
Modules and accessories are shutting down due to low Voltage.
Proper battery Voltage should be 12.6 Volts.
Proper charging Voltage should be 13.5-14.5 Volts.
Old 01-01-2017, 10:24 PM   #4
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
As I read the OP and the symptoms the first thought that came in my head was Voltage Regulator.
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 01-02-2017, 12:31 AM   #5
Jacanoryyy
My Ride: 318i
Ok thank you!
Old 01-02-2017, 12:31 AM   #6
Jacanoryyy
My Ride: 318i
Ok thank you
Old 01-02-2017, 12:32 AM   #7
Jacanoryyy
My Ride: 318i
Ok thank you will be checking this later on today
bmw
