Sponsored by The Tire Rack
Old 01-04-2017, 07:51 PM   #1
Mr.fixitautorepair
My Ride: 2000 bmw 328ci
Can i use 245/35/18 tires on 1999 bmw 323i
Can i use 245/35/18 tires on a 1999 323i? The rims are 18x8 +40 5x120, thanks for help you guys can offer. I'm just trying to sell the wheels to a buddy and he has a set of tires that size already.
Mr.fixitautorepair is offline   Reply With Quote
Old 01-04-2017, 08:00 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yes, 245/35-18 is a good tire size for an E46 chassis based on several different factors.
Though a 8" wide wheel is on the minimum side of what's considered acceptable, an 8" wheel still works with a 245/35-18 tire.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 01-05-2017, 09:19 AM   #3
Mr.fixitautorepair
Thanks for your reply rob!
