Old 01-06-2017, 01:55 PM   #1
patmappas
My Ride: 325xi
Oil Seperator
Hi guys I'm about to order a replacement oil seperator. I was wondering if there was a recommended one I should use. I'm on a budget right now and I'm considering this $40 one on Amazon
patmappas is offline   Reply With Quote
Old 01-06-2017, 01:59 PM   #2
Bigc2016
My Ride: 328i
can you post link to the one your going to get off amazon ?
Bigc2016 is offline   Reply With Quote
Old 01-06-2017, 02:09 PM   #3
patmappas
My Ride: 325xi
https://www.amazon.com/gp/aw/d/B00I3...2CCOVJH2&psc=1
Old 01-06-2017, 02:11 PM   #4
jmo69
My Ride: 03 325xi 98 328is
There's no link. Haven't dealt with mine yet but it is a PITA to replace, get all the hoses and O-rings because something is bound to break. This one is kind of elaborate but complete. https://www.fcpeuro.com/products/bmw...11617501566kt2 This is the separator by itself with a video on how to do it. https://www.fcpeuro.com/products/bmw...ve-11617501566
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 01-06-2017, 02:15 PM   #5
patmappas
My Ride: 325xi
Hopefully the link will show up now, it's a koolman. There's this video on YouTube by the 50's kid who just takes the whole intake manifold out which I'm probably going to do
Old 01-06-2017, 02:24 PM   #6
Bigc2016
My Ride: 328i
Here you go IMO follow this DIY by 50skid and replace all plastic and rubber that you can while changing out your CCV.
Dont forget your hard plastic coolant pipes and the kit you post should be ok.
Old 01-06-2017, 02:33 PM   #7
shiftyshadow17
My Ride: 2003 325xi
don't forget part 2
shiftyshadow17 is offline   Reply With Quote
Old 01-06-2017, 02:33 PM   #8
jmo69
If you take the manifold off there are a few things that should be done while it's off. The hard plastic heater lines for one, all the vacuum lines and even the starter, but that can be done with it on. You might want to consider new intake gaskets.
HERSHIS
Old 01-06-2017, 02:57 PM   #9
DEADF15H
My Ride: 2001 325i Auto
I don't know about Koolman. As time consuming and tedious as the kit is to Install, I'd go with a known quality mfg. It's hard enough to get everything reattached correctly so you don't throw any more codes, now you're adding a quality issue into the mix.
If you are going to sell the car just go with it and see, if keeping it, the fcpeuro.com option with a lifetime warranty is the way to go.
Sent from my SAMSUNG-SM-N910A using E46Fanatics mobile app
DEADF15H is offline   Reply With Quote
Old 01-06-2017, 04:47 PM   #10
austine46
My Ride: m54b25
dont forget to check out ecstuning.com too.. plus pull your hose that is connected to the valve cover(black plastic one) and see how it looks inside, if its clean you could get away with just doing the separator although i recommend doing it all while there and you dont need to remove intake manifold but its your call. my .02
everyone's a critic
FS: coupe facelift xenons, stock headers no cats, stock sport suspension for coupe, oil separator, non m coupe lip
austine46 is offline   Reply With Quote
Old 01-06-2017, 07:20 PM   #11
Zardoz33
My Ride: 2001 325xi
Brand: Koolman? You'll quickly learn some parts on these cars should be replaced with genuine-only. This is one of them.
Zardoz33 is offline   Reply With Quote
Old 01-06-2017, 08:22 PM   #12
Xarmius
My Ride: 2k5 330I ZHP
be careful with those cheap ones. I installed one i bought for 50 dollars and it failed within a few weeks. I ended up replacing one with a OEM one and when I was wondering why it failed so fast I cut it up and found the cheap one was missing a spring at the diaphragm and it soon filled up with oil. Go with a quality part because just to get to the part and replace all those tubes and seperator is not fun and is a huge PIA.
Xarmius is offline   Reply With Quote
Old 01-07-2017, 12:23 AM   #13
denise330xi
My Ride: 2002 330 xi
Also replacing those parts, depending on where you live, for me I live where it gets pretty cold in the winter, make sure you get the insulated hoses or you'll be changing them sooner then you want due to condensation. I just went through this process.
Good luck.
denise330xi is offline   Reply With Quote
Old 01-07-2017, 12:35 AM   #14
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
This kit that jmo69 linked is the one to get and only $121. All OE parts (high quality) and a complete set. Don't put any cheap Chinese junk parts on your car. They may look similar to the quality OEM parts, but they are total crap. Spend just a few dollars more and get the good stuff that works correctly and lasts a long time. The CCV job is enough of a pain that it's totally worth it to get the quality parts.
///Mmmmmm...
Old 02-08-2017, 08:55 PM   #15
Johntwayne
My Ride: 2001 330ci
This looks like a great deal but it says it does not fit my car ... I'm wondering why I have a 2001 330ci
Johntwayne is offline   Reply With Quote
Old 02-08-2017, 09:09 PM   #16
jmo69
Early engine? IDK but this one does https://www.fcpeuro.com/products/bmw...11617501566kt1
The throttle body gasket is different, plus an aftermarket intake boot
HERSHIS
Old 02-08-2017, 10:48 PM   #17
Johntwayne
My Ride: 2001 330ci
Hey thanks a bunch looks like exactly what I need sorry to thread jack ... anything else I should check while doing this job also about to do ofhg and order new belts and pulleys not sure if I should replace the tensioners or not?.
Old 02-09-2017, 12:13 AM   #18
jmo69
Don't know what to say about tensioners but pulleys and belts are a good idea. Just keep track of where the bolts go when you do the OFHG.
HERSHIS
Old 02-09-2017, 12:19 AM   #19
willysalazar1
My Ride: 2003 330ci
Don't buy Koolman I just changed mine and it is bad . When I open the oil cap Chewbacca sounds out the oil separator . Go OEM ..
Cheers
willysalazar1 is offline   Reply With Quote
Old 02-09-2017, 09:23 AM   #20
markusmarkus
My Ride: 2001 330Ci
^^^THIS^^^
ccv, oil seperator hose, pcv
