Sponsored by The Tire Rack
Old 01-07-2017, 10:32 PM   #1
Mfuhrer
My Ride: 325ci
Help tire sizing 325ci
I have a set of front 18inch M3 style 67 rims with a offset of 47, from the research I've done I know all all M3 fronts will fit. Next question would a square setup of 225/40/zr18 be ok?
My ride is a 02 325ci e46, I'm pretty sure this topic has been beatin from one side too another, I'm new to the e46 world just want to get the correct tire size for best compatible performance.
Mfuhrer is offline   Reply With Quote
Old 01-07-2017, 11:09 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yes, a square setup of style 67's with 225/40-18's all around will work well.
Buy light tires....
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 01-07-2017, 11:18 PM   #3
Mfuhrer
My Ride: 325ci
Alright thank you rob43
Would you have any tires to recommend as for the weight? I was looking at nitto neo gen series
Old 01-07-2017, 11:31 PM   #4
Rob43
Rob43's Avatar
I'm working on a similarly based thread, look for it in the Tire & Wheel forum...
Rob43
Old 01-08-2017, 12:44 AM   #5
Mfuhrer
My Ride: 325ci
Rob43 having a hard time to find your thread new this this site and community. Would you have a link?
Old 01-08-2017, 12:59 AM   #6
Mfuhrer
My Ride: 325ci
Rod43
Would these BF goodwrinch tire be ok ?
Weight24.7 lb. at $118 a tire
Or the michalin pilot super sport weighing at 22 lbs. at $170 a tire these are the lightest I can find
Old 01-08-2017, 01:23 AM   #7
Rob43
Rob43's Avatar
I haven't posted it yet,....wait until tomorrow.
Rob43
Old 01-08-2017, 09:50 PM   #8
Rob43
Rob43's Avatar
Done...
Rob43
