Old 01-11-2017, 07:51 AM   #1
shakkabakka
My Ride: 316i
thermostat
Hello. My engine dont get warm.. And because of this I want to change the thermostat!
I need some help to fint the thermostat on my 316i 2004. Got a picture of the engine in another 316i that I want to take the thermostat from.
Would be awsome if you could help me and maby paint a ring around the picture or something!
Thank you guys!
shakkabakka is offline   Reply With Quote
Old 01-11-2017, 08:47 AM   #2
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
I don't have a way of drawing, but it's behind the waterpump, which this that pulley directly behind your power steering reservoir (green cap). It actually looks like a challenge to replace on these 4-cyl engines (as opposed to the 6-cyl M52/M54).
I'd be a little hesitant to install a second-hand thermostat as you'll likely run into the same issue you're having now sometime soon down the road. The part is cheap enough that you can install a new one. If you do install the second-hand part, at the very least install new gaskets, and maybe even the lower radiator hose.
Check out www.realoem.com for a parts diagram, it should help you locate the thermostat.
-Gary
DiscoStu is offline   Reply With Quote
Old 01-11-2017, 09:08 AM   #3
ggenovez
My Ride: 325ci cabrio
Thanks Discostu, I actually found the diagram. You have a N42 engine. I'm sure if you go on youtube and search N42 thermostat you'll have a video that describes how to replace it.
http://bmwfans.info/parts-catalog/E4...ump_thermostat
ggenovez is offline   Reply With Quote
Old 01-11-2017, 09:08 AM   #4
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Check out here - I think this is the correct diagram for your t-stat location
http://www.realoem.com/bmw/enUS/show...diagId=11_3192
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 01-12-2017, 02:13 AM   #5
shakkabakka
My Ride: 316i
Thank you all! I'll check it out this weekend! Would it be easyer to take from under the car maby? I dont know how it looks if you remove those plastic covers under the car
Old 01-12-2017, 08:28 AM   #6
markusmarkus
My Ride: 2001 330Ci
No. You can't remove it from the under side. Remove the plastic covers on the engine. Go to www.realoem.com and enter the last 7 characters of the car's vehicle identification number. Hit enter and bookmark the page. Use realoem to see how the parts fit.
Old 01-12-2017, 09:19 AM   #7
shakkabakka
My Ride: 316i
Yea I've found it on realoem. But as you can see in the picture, its quite far down on the engine. But I guess I'll give it a try from above then. Thanks!!
engine, thermostat
