Old 12-14-2016, 09:06 PM   #41
slickware
My Ride: 323i
You'll have to jog my memory. When you say it hits 100-150, do you mean it drops to almost stalling? Or do you mean it idles high at 1000-1500? I don't remember what proper idle was on that car.
Wait, I'm dumb. You said while cranking. Hmm.
Did you do the vanos seals already?
slickware is offline   Reply With Quote
Old 12-14-2016, 09:21 PM   #42
jfoj
My Ride: 330CiC, M5, X5, E93
Not buying VANOS seals are a major contributor to long cranking.
I would be looking at other basic things long before VANOS seal replacement.
Old 12-14-2016, 09:22 PM   #43
slickware
My Ride: 323i
It sounds like he's looked at all the things I did before arriving at the vanos option. All I can tell you is that it absolutely fixed my issue when it happened to me.
fuel, shitbox, stalling, starting, vanos
