Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
Old 08-11-2014, 10:25 AM   #21
avincent52
My Ride: 325iT 5 speed/Sport
Glad this worked for you. I had forgotten I posted this, but the advice from this site has saved me thousands of dollars, so I'm happy to share a little with my fellow Fanatics.
avincent52 is offline   Reply With Quote
Old 08-11-2014, 10:52 AM   #22
phoopsta
My Ride: 02 330xi 3-pedal
hmm I am starting to think it may be actually a battery. It is still wanting to work when it waANTS. I thought this solved the problem but the problem is back.
______________________________________________
phoopsta is offline   Reply With Quote
Old 08-11-2014, 06:11 PM   #23
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Broken connection, cracked solder joint or component most likely. If it works best right after charging then likely a bad MOSFET.
scottjoh is offline   Reply With Quote
Old 08-11-2014, 06:26 PM   #24
Mr Podman
My Ride: E46 Coupe
My car is coming up to 15 years old. I still have both original keys and they both work.
Recognizing that the car charges the batteries in the keys,
I have a rolling reminder in my To Do list to swap the keys every 3 months.
Works for me.
Mr Podman is offline   Reply With Quote
Old 08-11-2014, 06:28 PM   #25
phoopsta
Mine just works when it wants. I can go for a drive and park and it wont work. I come back the next morning it works. Go for a drive and park it again. Works... go in and have a sandwich, come out and it doesnt work. Forgot my wallet in the sandwhich shop, come back out and it works. Wtf.
Ok I know that may of not made sense but thats what happens.
Old 08-11-2014, 07:25 PM   #26
scottjoh
Modded ///Member
It may not make sense, but, that's what I see all the time coming in for repair.
Old 08-12-2014, 07:03 AM   #27
fourtysix
My Ride: e46
i had one key that worked sparringly and the other was dead.
i just did this and it worked like a charm on the dead key.
i can even roll down my windows via remote now.
thanks for this
fourtysix is offline   Reply With Quote
Old 08-21-2014, 12:37 PM   #28
gambit2099
My Ride: 01 bmw 325i
i have a new key from dealer an i got this car aout of action in great codition but i try all ways i read here or on you tube for sync key an still no go it will not work any other ideas i should check thanks 01 E46 ..
gambit2099 is offline   Reply With Quote
Old 03-18-2015, 08:33 AM   #29
BUDGET76
My Ride: 03' M3 & 95' 330TI
Just picked up my M3 with 1 fob working, and 1 brand new looking one not working. Synched, and now both work perfect
Now I need to get the memory setup for the seats/mirrors, it definitely has someone's settings saved to the newer key.
BUDGET76 is offline   Reply With Quote
Old 10-18-2015, 09:13 PM   #30
BillyBobJOnes
My Ride: 2000 323i e46
I am very very happyyy
Hahah I got kinda down that my key in working snd so I thought the battery was dead kept trying this trick it wouldn't work...eventually I realized my doors were locked
Unlocked them all and it worked right away I was so happy. Thank you!!
BillyBobJOnes is offline   Reply With Quote
Old 11-02-2015, 03:12 AM   #31
ti317
My Ride: 02 330ci coupe 5 spd
E46s came with 4 keys. 2 key fobs, 1 valet and 1 plastic emergency key.
Why would anyone not obtain all 4?
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 11-02-2015, 02:35 PM   #32
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
My car is 16 years old and I have all 4. Original as well
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 11-02-2015, 05:25 PM   #33
ti317
A Fanatic! Like me.
Every car I own, has all of its keys, all originally supplied tools and the owner's manual, until the day I part with it.
If I lend one of my daughters or my wife the car, I give them the second key and I don't have to worry about my seat, mirrors, A/C setting, or radio presets.
If I get my car detailed, I deadbolt the trunk, lock the glove box and give the valet key for use.
I have my wife keep the plastic key in her purse in case I lose the keys (I keep my primary key and valet key on a splittable key chain) or I keep it on a separate key chain with my house key.
Old 11-02-2015, 06:54 PM   #34
franz
My Ride: 03 330i
I am trying to understand what is being said/done here
franz is offline   Reply With Quote
Old 11-02-2015, 07:14 PM   #35
mooseX
My Ride: 03 330xi 6 gears
my first 4 E46's came with just one lousy key BUT all were in working order. Just bought my latest 330xi and to my surprise got 3 keys! None of them are charged though. Thanks I'll try this out
mooseX is online now   Reply With Quote
Old 01-19-2016, 08:16 PM   #36
Option_d
My Ride: X5
Good info.
I've recently replaced the battery on my 2nd key and have got it working. However whenever I program the 2nd key to work, the original first key stops working. I can reprogram the 1st key to work but then the 2nd key stop working. I just can't get both keys to work together. Any suggestions?
Thanks in advance.
Option_d is offline   Reply With Quote
Old 01-20-2016, 03:35 PM   #37
scottjoh
Modded ///Member
Originally Posted by Option_d View Post
Good info.
Thanks in advance.
Do the procedure again, but, DO NOT, put the 2nd key in the ignition.
Old 01-20-2016, 04:32 PM   #38
jfoj
My Ride: 330CiC, M5, X5, E93
Not really true, the early E46 came with 4 keys, however the plastic spare/wallet key was phased out for build dates as of 11/2003.
Many used cars come with only one key, after many moves, owners, many auctions, divorces, repossessions, dealers having all the original keys is next to impossible.
Often the keys can get lost just inside a disorganized dealer during a trade or even if car has a full set of keys from an auction.
I purchased a new vehicle from a dealer once and they could only find one key. I really pushed for them to find the other original key, they offered to get a replacement, however, I wanted the originals. After a lot of work by the admin staff in the back office, they finally found the key in the bottom of the file cabinet where it fell out of the folder.
Old 05-30-2016, 01:12 AM   #39
Peterabram
My Ride: bmw
Actually,I had a situation where the car would not start. I pushed the start button and I got a message that FOB was not recognized. The car would not start till I held the FOB next to the plastic door.Then i find Sunrise Locksmith and really they are commendable and provide awesome locksmithing service._nr_
Peterabram is offline   Reply With Quote
Old 05-30-2016, 10:36 AM   #40
jmo69
My Ride: 03 325xi 98 328is
Didn't know e46's were available with push button start.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
battery, dead, key, remote, replace
