Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
Old 05-31-2016, 01:48 AM   #41
Beemer4life
My Ride: 1999 BMW 328i E46
I know this is an old post by Wow!! Awesome it worked for me. I had to try it a couple of times but in the end it worked. Thank you
Beemer4life is offline   Reply With Quote
Old 09-20-2016, 03:59 PM   #42
kieckarys
My Ride: e46 320d m sport
iv e46 320d sport 2004 i have 1 key and remote central locking does not work using it, i changed battery and tried all the possible ways to reset the system thing without success.. note that when i switch engine off after a drive and take key out of ignition it should unlock the doors but it doesnt, i also have bmw x5 which unlocks all doors when taking key out of ignition..could it be the GM5 module gone? the inside lock button works fine and i checked central locking fuses everything works as it should apart from remote locking
kieckarys is offline   Reply With Quote
Old 09-21-2016, 12:51 PM   #43
scottjoh
My Ride: '99 323i & '02 540i
General module found fine. The automatic unlocking is a car/key memory setting and is probably not enabled or they key is no good. Did you verify that the old battery was bad and needed to be replaced. I bet it was fine.
scottjoh is offline   Reply With Quote
Old 09-21-2016, 02:23 PM   #44
kieckarys
no i did not verify that battery was bad i just assumed it was cuz i never had such problem before with any bmw i had. so now im more confused since the battery is good and it simply doesnt work
Old 11-24-2016, 01:17 PM   #45
Yankeebmwgirl
My Ride: 2001 BMW 325xiT
Send a message via ICQ to Yankeebmwgirl
Stupid question before I try this with my key...which button on the diamond key is the unlock..with the top being the place the key ring goes...tell me which buttons I am to push.
Yankeebmwgirl is offline   Reply With Quote
Old 11-24-2016, 03:43 PM   #46
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
1. Locks all doors and trunk
2. Unlock (depending on programming once or twice for all doors )
3. Trunk unlock
Edit: Image credit: http://www.transpondery.com/remote_p...ogramming.html
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 11-24-2016, 04:31 PM   #47
Yankeebmwgirl
Thanx for the instructions. Is button one the top buttonby the key ring
battery, dead, key, remote, replace
