Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 11-07-2016, 11:35 PM   #361
Herbert330i
My Ride: 2003 330i
Only had the car for about 8 months, no I haven't but I have been fixing everything else (cooling system overhaul, suspension, ignition). I'll have to take another look then but this is the rear of the trans, I dont see how oil can end up there
Herbert330i is offline   Reply With Quote
Old 11-09-2016, 10:00 PM   #362
cwithbmw
My Ride: 2002 330Ci 2009 335i
Originally Posted by lllRazorlll View Post
Upper radiator hose probably not 100% seated. It will look like it is attached fully, but it needs to be covering all ridges on the male end completely.
cwithbmw is offline   Reply With Quote
Old 11-14-2016, 08:02 PM   #363
paulo985
My Ride: 2004 330ci E46-M54
Thanks so much for posting these. It is a great resource, especially for a new owner of a 04 330ci! when I stop the car I can smell that tell tale oil burning smell. Do you have any suggestion where I should look first in this symptom? Valve cover Gasket? I know I have a transmission oil leak from somewhere up in front like the main shaft seal. unfortunately.
thanks again paulo985
paulo985 is offline   Reply With Quote
Old 11-14-2016, 09:23 PM   #364
lingon300k
My Ride: 2005 325xi Automatic
The answer to your question is in the first post on this thread.
lingon300k is offline   Reply With Quote
Old 11-14-2016, 10:59 PM   #365
paulo985
Got it. Thanks.
Old 11-15-2016, 05:03 AM   #366
Stegsa
My Ride: 330ci convertable
Hi Paulo I tried finding it myself,there is no room in tha v6 engine there was oil everywhere!,I put in garage they steamed it and found it was oil gasket housing hope this helps
Stegsa is offline   Reply With Quote
Old 11-19-2016, 02:02 PM   #367
Suryateja
My Ride: 325 CI
Ok, so update : I have changed my coolant expansion tank... but im still having a leak. Its coming from the seam where the upper radiator hose connects into the radiator. The upper hose has 2 connections.. one goes to the radiator and the small one to the expansion tank. The small one is not seating properly into the male connector of the tank.
Also, when i take it for a short drive, i can see steam forming up and evaporated from somewhere beneath the upper hose....Help needed!!!
Suryateja is offline   Reply With Quote
Old 11-19-2016, 02:02 PM   #368
Suryateja
My Ride: 325 CI
Old 11-20-2016, 10:44 PM   #369
zeke330ci
I have a leak on my 330ci coming from my transmission. I think it's output shaft seal..
zeke330ci is offline   Reply With Quote
Old 11-20-2016, 10:45 PM   #370
zeke330ci
Trying to see if anyone else has dealt with this problem
Old 12-02-2016, 03:14 PM   #371
stevemd
My Ride: 330i, XC60, Mazda 6
Oil on Thermostat Housing
Looking down to the 'stat housing from the top, I can see what looks like oil on and around the electrical connection.
Looking at it from under the car, I see more oil on the bottom of the 'stat housing. Could that be from when the mechanical fan failed? I can't figure out where else it the oil could be coming from.
Valve cover gasket new.
Thanks!
stevemd is offline   Reply With Quote
Old 12-03-2016, 08:35 AM   #372
bradleyg
unregistered user
My Ride: '02 325ci
^^Take some brake cleaner and spray that area down and wipe it all away real well and see if more seems to appear. If none, it was some residual seepage from something else. If there's fresh oil trace it back to where it came from.
bradleyg is offline   Reply With Quote
Old 12-03-2016, 11:13 AM   #373
lingon300k
Thanks!
Clean it first, and see if it comes back. If it does, it's most likely a bad VANOS line, or the last person to remove the VANOS line didn't use new crush washers.
Old 12-06-2016, 08:10 PM   #374
stevemd
True, Leak 101 calls for cleaning the area then monitoring to see where it is coming from.
Old 12-08-2016, 06:20 PM   #375
DEADF15H
My Ride: 2001 325i Auto
Here's a negative review on the Bear radiator, for those thinking of going the aftermarket route.
http://forum.e46fanatics.com/showthread.php?p=17133493
Sent from my SAMSUNG-SM-N910A using E46Fanatics mobile app
DEADF15H is offline   Reply With Quote
Old 12-12-2016, 07:30 PM   #376
toomuchsauce
My Ride: 2006 325Ci
Can anyone tell me what part this is?
Noticed a burning oil smell recently and for the first time today it started to give off a white smoke coming from that exact part where the leak is shown.
Also, the image appears to have uploaded sideways, it should be rotated clockwise. For reference, it is on the passenger side by the smog pump air injection check valve.
Edit: It's the O2 sensor.. Could the oil just be coming from a valve cover gasket leak?
toomuchsauce is offline   Reply With Quote
Old 12-12-2016, 08:17 PM   #377
Archbid
My Ride: 2003 330cic
Get it on a lift. My leak was from the detent covers. Cheap part, incredibly expensive repair. I'll DIY it one day.
Also look at rear main seal
Archbid is offline   Reply With Quote
Old 12-12-2016, 08:54 PM   #378
bradleyg
unregistered user
My Ride: '02 325ci
Yep. It gets down on the heat shield then burns off.
Replacing the valve cover gasket is pretty easy and cheap to do.
Old 12-12-2016, 10:42 PM   #379
lingon300k
Sounds like the valve cover gasket to me. Meistersatz and Genuine BMW are both ACM rubber gaskets, which makes them preferable to the rest.
http://forum.e46fanatics.com/showpos...9&postcount=20
Old 01-02-2017, 01:59 AM   #380
bulletpruf
My Ride: 1999 318i E46
Great thread! My 99 318i with the M43B19 is leaking. Not the trans; either power steering or engine oil. Need to do some cleaning and checking.
bulletpruf is offline   Reply With Quote
