Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 01-11-2017, 08:32 PM   #3381
Stinger9
My Ride: '04 330Ci
Originally Posted by BMOne View Post
I can hear a slight chirping sound when first starting the car in the morning, seems to go away after. coolant level looks good and I haven't needed to put in anymore in today.
Is it really not recommended to open the bleed screw just a bit when it's warm/hot to lose the air?
Temp seems to go up to 98c (seen it at 99c for a sec) then goes down is this normal ?
Please learn how not to double post. And erase one of the dupes so we won't be seeing double for years.
Chirping is very likely a drive belt bearing on the way to fail. Learn how to tell which one is bad or replace all three before you reach catastrophe soon. I'm not kidding.
Opening the bleed screw when warm and running will not only do no good, it will do harm. It will lose the good bleed you may have had.
Learn the in's and out's of your car better as these are beginner questions. Your car will stay in better shape that way.
Fluctuating temp may be due to old thermostat, or less than a perfect bleed. You must follow the procedure accurately.
Old 01-11-2017, 09:20 PM   #3382
jmo69
My Ride: 03 325xi 98 328is
Pull the belt and spin the tensioner and idler pulleys, they should be silent. Or use a wooden dowel and touch something solid as close to each pulley as possible. On the idler you could use the bolt that holds it on and hold the other end to your ear, the sound will transmit through the dowel. Just be careful of the belts.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 01-14-2017, 03:46 PM   #3383
Mr.Wilson
My Ride: 04 e46 325i
if you cant get bmw coolant get Zerex-G48 closest and best other than that dont do it lol
Mr.Wilson is offline   Reply With Quote
Old 01-17-2017, 06:19 PM   #3384
bezender
My Ride: 328i
Hi all,
after doing a cooling system re-fresh another weak point has come to light...
i have the ol' misty windscreen so it looks like im in for some heater core fun. Does anyone know if there is a way to tell what type of heater core i would have prior to pulling the stereo etc. out?
this:
http://www.realoem.com/bmw/enUS/show...diagId=64_0818
Or this:
http://www.realoem.com/bmw/enUS/show...diagId=64_0993
Cheers lads,
Carl
bezender is offline   Reply With Quote
Old 01-17-2017, 07:51 PM   #3385
jmo69
This one is for cars built up to 9/1999 http://www.realoem.com/bmw/enUS/show...diagId=64_0993 what's your build date?
Hers His
Old 01-17-2017, 08:34 PM   #3386
bezender
My Ride: 328i
Thanks jmo69, I dont know the build date off the top of my head but it was a '99 car so thankfully i asked!
Old 02-07-2017, 02:53 AM   #3387
KimberleyRenee
My Ride: BMW 2000 318i
Sorry for the silly question, but how can I find out whether my expansion tank has been replaced? As I've bought the car with no service history ( I know, could be tragic ) to me it looks newer, but then again I'm new to the e46 and I'm still trying to figure what needs to be done.
KimberleyRenee is offline   Reply With Quote
Old 02-07-2017, 06:15 AM   #3388
bmwdude330
My Ride: E46 330i ZHP
If in doubt, replace it.
bmwdude330 is offline   Reply With Quote
Old 02-07-2017, 06:19 AM   #3389
Mbryant616
My Ride: 2004 325Ci Vert
It's recommended that you do a full cooling system refresh. Don't wait for even one item in your cooling system to fail - as it could be the end of your engine. I bought mine in Dec 2016 with 99k miles, a few records, and runs like a top. But I will be replacing the entire system per Mango's recommendation, as soon as the weather gets a bit warmer. I have all the parts already in the garage. If any of the parts I replace look to be in really good shape, might be able to sell them on ebay.
Mbryant616 is offline   Reply With Quote
Old 02-07-2017, 02:56 PM   #3390
KimberleyRenee
Yes I think it's probably the safest option to just replace everything to save any future hassle.
So from reading a bit of information I should not purchase anything except OE parts? There are cheaper parts on ebay but even being a young women with little knowledge I have some scepticism as to whether they will do my car any justice or just break within a couple of months and cost me more money!
Sorry if I seem like I have no idea, there is just soooo much information on here I'm having a hard time trying to figure out what's right or wrong! I have a 2000 318i in titanium silver, it's my baby and the very last thing I want to do is ruin it!
Old 02-07-2017, 03:20 PM   #3391
tailendcharlie
My Ride: 02 330i
For critical parts like coolant hoses or expansion tanks most folks would advise OE. If there is a large number of users reporting good results with non-OE parts, then you can probably justify going that route. Certainly for something like an A/C compressor few owners would go with genuine BMW. You have to do some searching to find a consensus depending on the part. In general, most advise steering clear of Chinese parts which can bd confusing since some "OEM" parts could in reality be made there. Gotta do your homework.
tailendcharlie is offline   Reply With Quote
Old 02-07-2017, 03:40 PM   #3392
Mbryant616
I found that many more experienced E46ers are using FCP Euro to order most critical parts - they may not always be cheapest, but have a Lifetime Warranty on everything. I have found them easy to order online and shipping is usually free (over $49 in purchases). Shop ebay at your own risk! But saving a few bucks isn't worth it to me. (at least on mechanical items)
Old 02-08-2017, 10:10 AM   #3393
lingon300k
My Ride: 2005 325xi Automatic
They also price match. https://www.fcpeuro.com/page/price-match
lingon300k is offline   Reply With Quote
Old 02-08-2017, 10:22 AM   #3394
adwebinc
My Ride: '02 330Ci
+1000 on fcp. Great service, great prices and lifetime guarantee!
Sent from my iPad using Tapatalk
adwebinc is offline   Reply With Quote
Old 02-08-2017, 01:37 PM   #3395
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
Thumbs Up
Eurobahn BMW MMINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro NC dealership.
Eurobahn BMW is offline   Reply With Quote
Old 02-08-2017, 01:39 PM   #3396
KimberleyRenee
Thank you for the information! Much appreciated! Although I've had a look at the site that you provided and it seems they don't stock parts for the 318i model? Well I can't seem to find them anyway! :/
Old 02-08-2017, 03:16 PM   #3397
Kpriest
My Ride: 2005 325i
Double check your production date on the drivers side door sticker. The 318 seems to have only been made through 1998 in the US. After that the 323 in 99-00.
According to Edmonds.com
Kpriest is offline   Reply With Quote
Old 02-08-2017, 06:05 PM   #3398
bezender
My Ride: 328i
Hi all,
Against Mangos better advice, I thought I got away with re-using the ET base... it appears the plastic around the auto trans thermostat was too stressed and after 2 months worth of daily driving heat cycles in 40 degrees celsius (100f for the feet and inches crowd) unsurprisingly it split and started a slow leak.
I have a replacement ET base, and what I would like to know is; Will I have enough room after removing the airbox to replace this part without removing the fan and radiator from the car?
moral: listen to mango, especially if you live somewhere that gets proper hot
Old 02-09-2017, 11:40 AM   #3399
CrazyOneToo
My Ride: 1999 328i 4dr
www.ecstuning.com
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 02-09-2017, 01:29 PM   #3400
My Ride: Lexus
Originally Posted by bezender View Post
Hi all,
Thank you sir! "Listen to Mango" definitely sounds better than listen to the fruit. But these days--I'll take either!
As far as your install question, I'm not sure. It's been a while since I've been under the hood. These days, my ponytail just flaps in the wind. Sorry, I hope you figure it out, though.
Good luck!
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
